alexg89 Posted February 7, 2020 Author Report Share Posted February 7, 2020 (edited) Good questions, only thing i could find on a quick search is https://www.engine-specs.net/nissan/ka24e.html has majority of the info Piston pin outer diameter: 20.989-21.001 mm (0.8263.0.8268 in) Connecting rod center distance: 164.95-165.05 mm (6.4941-6.4980 in Edited February 7, 2020 by alexg89 Quote Link to comment
Stoffregen Motorsports Posted February 7, 2020 Report Share Posted February 7, 2020 15 hours ago, G-Duax said: If you ever get a chance, look through old hot rod magazines, and books from the '50s & '60s. The amount of work people went through, like stretching rods, and welding up piston domes. This was way before you could enter an order with a speed shop like Summit, and order H-beam rods, or off the shelf high compression pistons. We used to cut valve reliefs in the piston domes with a drill press and a valve-turned cutter by welding and grinding on it. Performance has come a long way. Quote Link to comment
Lockleaf Posted February 18, 2020 Report Share Posted February 18, 2020 Here's a combo I came up with a while back, though I've never done anything with it. Caveat emptor, but here is what you can use to create low 9s:1 compression in a single cam KA. You can even junkyard all the parts if you are feeling super frisky 👍. You will need: Ford 5.4 L connecting rods Honda/Acura J32A3 pistons (specifically these pistons. they have the correct compression.) You will need to have the big end of the connecting rod bored to the KA crank. You will need to have the small end of the connecting rod narrowed to fit inside the piston. The big end of the connecting rod is narrower than the stock KA rod by some amount. In theory could allow the rod to walk back and forth in the journal, but I don't know how that would play out in fact. Build, return, and report. I want to know if that crazy combo actually assembles a running engine 😄 1 Quote Link to comment
datzenmike Posted February 19, 2020 Report Share Posted February 19, 2020 Or mill the KA24E head 0.5mm for a 9.03 compression. Or mill the KA24E head 0.75mm for a 9.13 compression. Or mill the KA24E head 1.0mm for a 9.3 compression. The KA pistons stop 0.45mm from the deck surface so the above plus mill the deck 0.5mm for 9.68 compression. The above plus a 0.5mm (0.020") copper head gasket for 10.09. That's got to be cheaper and easier and likely you will be having the head milled anyway. Quote Link to comment
Lockleaf Posted February 19, 2020 Report Share Posted February 19, 2020 1 hour ago, datzenmike said: Or mill the KA24E head 0.5mm for a 9.03 compression. Or mill the KA24E head 0.75mm for a 9.13 compression. Or mill the KA24E head 1.0mm for a 9.3 compression. The KA pistons stop 0.45mm from the deck surface so the above plus mill the deck 0.5mm for 9.68 compression. The above plus a 0.5mm (0.020") copper head gasket for 10.09. That's got to be cheaper and easier and likely you will be having the head milled anyway. FINE! Spoil sport. If its any help, mine is a long rod.... 😄 1 1 Quote Link to comment
alexg89 Posted February 19, 2020 Author Report Share Posted February 19, 2020 Nissan KA24E 2.4L SOHC 12 valve 89-90 240SX Stock Bore: 3.504, 89mm Stroke: 3.780 Rod: 6.496 Head cc: 62.0 Gasket: .045 Deck: .000 Bore Comp. Dome Compression RatioComp. Gram Part Required in/mm Height CC w/ Stock Head Wt. Number Ring Set Dome top All motor/Nitrous 3.504 / 89.00 1.340 10.4 10.7 364 3530100 1012283504 This is what i will be buying from Carrillo .. Local shop has them in stock and will be about 520 bucks .. 1 Quote Link to comment
alexg89 Posted February 19, 2020 Author Report Share Posted February 19, 2020 (edited) On 2/7/2020 at 10:59 AM, Stoffregen Motorsports said: Performance has come a long way. By chance do you know with the above information if i deck the head .020 or .030 will there be an issue with valve clearnce? information i have on my cam is 270 duration and 445 lift as to where the stock was 232 duration .382 lift Edited February 19, 2020 by alexg89 Quote Link to comment
Stoffregen Motorsports Posted February 20, 2020 Report Share Posted February 20, 2020 Valve clearance only becomes a problem with pop-up pistons and huge cams. 1 Quote Link to comment
