Charlie69 Posted October 20, 2018 Report Share Posted October 20, 2018 You are correct on the usage of the 2 wire temp sender usage. 1985 1986 720s feedback carb trucks have this 2 wire sender also. Quote Link to comment
datzenmike Posted October 20, 2018 Report Share Posted October 20, 2018 Ahh, wasn't sure. 1 Quote Link to comment
jagman Posted October 23, 2018 Author Report Share Posted October 23, 2018 Now I have replaced the head, timing chain and sprockets and replaced the carb with a weber from redline. I did not connect the round plug that went to the carb. I also deleted the vacuum lines to anything not needed including the egr valve. Everything appears to be correct but I get no power to the starter solenoid. On a fully charged battery I just get one click and then nothing. The Haynes manual has no illustrations on the wiring (round connector) to the carb. Which wire controls the electric choke? Need help once again. Thanks Steve. Quote Link to comment
datzenmike Posted October 24, 2018 Report Share Posted October 24, 2018 Have someone turn the key while you get under the hood and watch... Does it click every time you turn the key to START? If so then the solenoid is partly working. It's job is twofold. It must 1/ electrically connect the battery positive cable too the starter windings AND 2/ it must push the star gear on the starter armature out and engage the flywheel ring gear. 1 Quote Link to comment
