New Member SR521
  • Replies 41
I got the intercooler in today. The fit is still tight with the rad. I got a Honda EG aluminum one from ebay just because its the smallest 2 core rad I could find. Im considering machining the crank pulley to eliminate the outter row so I can get some better clearance. Whats intercooler and radiator setup are you guys using for sr swaps in the 521??
10 hours ago, mrbigtanker said:
check out my page in the 521 section. water to air is what I did.
Nice truck! My wallet isn't as deep as yours. I have to work with what I got. I think with a little massaging it will fit. Maybe I have to cut the facia but I dont want to do that. I would like to keep the grill.
On my 520 I modded the radiator support in order to fit the L20B.  The 520 is about 5" shorter from firewall to radiator support.  This made it possible for me to install a two core with  1" tubes aluminum radiator, shroud, and dual 12" fans.   I am also running AC condenser and still have stock location for the stock grill.
Edited by Charlie69
I hear ya, cut as far back as the bottom trim will allow. stainless for the under grill side. Thats what I did before to mount the pusher fan, very clean.
  • Thanks 1
  • 1 year later...
