Dirtyowlnumber4 Posted November 20, 2017 Report Share Posted November 20, 2017 I ordered a clutch kit online and everything seems to check out okay except the throwout bearing, see the old bearing pressed straight against the hub and still spun, but if the new one is pressed all the way back it hits the dustcap on the bearing and stops spinning. I ordered another one from an auto parts store, but it was the same deal. I couldn't find an original part on ebay either. I am worried that if i use the clutch enough it will nudge the bearing back eventually and break it. Anyone else dealt with anything like this? Quote Link to comment
Doctor510 Posted November 20, 2017 Report Share Posted November 20, 2017 You might have pressed it on backwards. 1 Quote Link to comment
Dirtyowlnumber4 Posted November 21, 2017 Author Report Share Posted November 21, 2017 I faced the side with the print on it outwards, but it is the same story either way it goes on. Quote Link to comment
datzenmike Posted November 21, 2017 Report Share Posted November 21, 2017 This way out to the clutch. The rounded bump all the way round presses against the clutch diaphragm fingers. That part should spin easily with your fingers while holding the outside of it.. . 1 Quote Link to comment
KELMO Posted November 21, 2017 Report Share Posted November 21, 2017 Nissan part # 30502-21000.....incase the aftermarkets ain't working. Quote Link to comment
Dirtyowlnumber4 Posted November 21, 2017 Author Report Share Posted November 21, 2017 Ah thanks mike and doctor thats the ticket I've been a fool 1 Quote Link to comment
KELMO Posted November 21, 2017 Report Share Posted November 21, 2017 Not a fool, learning by trial and error. I've built 2 cars mostly by error. :thumbup: 1 Quote Link to comment
datzenmike Posted November 21, 2017 Report Share Posted November 21, 2017 There's book learning, learning by following a good example and there's learning by mistake. This is good, better, and best. Hard learned is hard earned. 1 Quote Link to comment
