82baggeddatsun720 Posted August 12, 2017 Report Posted August 12, 2017 I need to find someone who is selling some custom upper control arms so I can fix my camber and caster and any help would be great. 1 Quote
wayno Posted August 12, 2017 Report Posted August 12, 2017 What did you do that you need upper control arms? 1 Quote
thisismatt Posted August 12, 2017 Report Posted August 12, 2017 By his username, I'm guessing he bagged/is trying to bag it. 2 Quote
wayno Posted August 12, 2017 Report Posted August 12, 2017 Well the first thing I would do is take the stock upper control arms, grind the lip off on the top where the ball joint goes, flip them upside down and put the right one on the left, and the left one on the right. If he still has negative camber then I would lengthen them just enough to be able to align the front end. Flipping them upside down makes it so the upper ball joints don't bind, since I re-located my tension rods to the rear and I cut off the front tension rod mounts I can lower mine so far the cross member below the oil pan rests on the ground and the ball joints still don't bind, at the moment that cross bar on my 520 is 2 5/8ths inches off the ground, any lower and it hits stuff, right now it only hits the ground when I dive off the back side of the very large speed bumps we have around here if I am driving over 15mph when I hit them. 1 Quote
DAT{521}SUN Posted August 14, 2017 Report Posted August 14, 2017 Here's another option. http://www.ebay.com/itm/Datsun-Nissan-pickup-adjustable-custom-upper-control-arms-/192274764822?hash=item2cc4781416:g:1FcAAOSwqYBWnTlE 2 Quote
paradime Posted August 15, 2017 Report Posted August 15, 2017 By his username, I'm guessing he bagged/is trying to bag it. Very observant. 1 Quote
2wheel-lee Posted August 16, 2017 Report Posted August 16, 2017 Find username beebani here or on ebay. He's most known for making them for 620s, but he also makes them for 720s and D21s as well as others. Good guy to work with. http://www.ebay.com/usr/beebani1028?_trksid=p2047675.l2559 2 Quote
