Z20
Diego2o9
  • Replies 5
Look on the engine tag below the pass side hood hinge on the inner fender. Second line up from the bottom...
Engine Z20(S) 1965...... if it says this.....
You can only use, (should only use) a Z20(S) head from another '83-'86 720 to retain your stock compression.
Negative.
Waiting to hear back about what the engine tag says or if this is a swapped Z20
The 720 Z20S head has a much smaller combustion chamber, around 45cc. All other car Z20/Z22 and truck Z22/24 heads are 57cc. The truck Z20S head even had two small quench areas on each combustion chamber. (top and bottom, below)
All other Z20/22/24 heads are larger and round.....
Z20, z22, z24. These heads will go on without any modification.
Anything else will require additional parts and/or further modification.
While they will go on, the Z24 head has larger and differently shaped intake ports. The Z20/22 had smaller round ports so use the Z24 intake gasket for the best seal on a Z20/22 intake
