DatMo Posted August 1, 2016 Report Share Posted August 1, 2016 Unfortunately I'm not able to get pictures at the moment but I put my coil next to my radiator. I'm only driving the car for street use but do you think the heat will be okay? From what I know, I think it'll be okay because I've seen v8 guys run them on the block. Quote Link to comment
MikeRL411 Posted August 1, 2016 Report Share Posted August 1, 2016 Insufficient info to deserve a meaningful reply. WHAT VEHICLE AND YEAR!!!!!!! 1 Quote Link to comment
Laecaon Posted August 1, 2016 Report Share Posted August 1, 2016 Insufficient info to deserve a meaningful reply. WHAT VEHICLE AND YEAR!!!!!!! Really not insufficient info. Coil next to radiator can apply to any car, and is basically the same on all cars. Rock it. You will know if its a problem. I doubt it will be a problem for a long time. Quote Link to comment
datzenmike Posted August 1, 2016 Report Share Posted August 1, 2016 I don't see a problem as long as there is room around it for air flow. Probably cooler there than a foot away from the exhaust manifold on the inner fender. Quote Link to comment
banzai510(hainz) Posted August 1, 2016 Report Share Posted August 1, 2016 I got mount mounted to the rad on one car. Will be fine Quote Link to comment
TENDRIL Posted August 1, 2016 Report Share Posted August 1, 2016 had my matchbox coil set up like this worked just fine for years and multiple canbys Quote Link to comment
DatMo Posted August 2, 2016 Author Report Share Posted August 2, 2016 Sweet!! Thanks guys! Quote Link to comment
