79datsun620 Posted October 20, 2008 Report Share Posted October 20, 2008 i want to put an electric cooling fan on my 79 620 & ive got a water pump from a 76 280z that does not have the built in fan clutch,will it bolt up to my L20b thank ya:D Quote Link to comment
]2eDeYe Posted October 20, 2008 Report Share Posted October 20, 2008 It'll bolt up, but you will need to move the pulley out to match the crank and alternator pulleys. Quote Link to comment
79datsun620 Posted October 21, 2008 Author Report Share Posted October 21, 2008 Gotcha Quote Link to comment
banzai510(hainz) Posted October 21, 2008 Report Share Posted October 21, 2008 use the stock pump so you dont have to worry about the pulleys The later 620s have 3 cores rads I belive,just install a 160deg 54mm size stat. if still dont work then add the electric fan Quote Link to comment
79datsun620 Posted October 21, 2008 Author Report Share Posted October 21, 2008 so your sayin i might can run it without any fan at all:blink: Quote Link to comment
slodat Posted October 21, 2008 Report Share Posted October 21, 2008 I would not run it without a fan. Bad idea. I just converted my '79 620 from the stock clutch type water pump to the older style pump with no clutch. I pulled the pulley and fan from the salvage yard off an earlier L powered car/truck. Very easy conversion. No real down side. The up side is the truck is a LOT quieter thanks to the fan. Hope this helps. Quote Link to comment
]2eDeYe Posted October 21, 2008 Report Share Posted October 21, 2008 The Z pump has a higher volume output than the 620 pump. ...and fan clutches suck :D Quote Link to comment
slodat Posted October 21, 2008 Report Share Posted October 21, 2008 I know the Z pump moves more water, but the pulley thing is a PITA. I just bought a Japanese water pump for a 510.. Man the truck is a LOT quieter! Quote Link to comment
]2eDeYe Posted October 21, 2008 Report Share Posted October 21, 2008 Spectre has spacer kit's, as well as some other manufacturers. I picked some up at Shmucks. Quote Link to comment
ppeters914 Posted October 22, 2008 Report Share Posted October 22, 2008 2eDeYe;90360'']...and fan clutches suck :D Yeah, one of those good ideas on paper, but not in the real world. Quote Link to comment
datzenmike Posted October 22, 2008 Report Share Posted October 22, 2008 2eDeYe;90360']The Z pump has a higher volume output than the 620 pump. ...and fan clutches suck :D L20B water pump. http://i138.photobucket.com/albums/q251/datzenmike/Lenginewaterpump.jpg[/img]"] Z20/22/24 water pump. http://i138.photobucket.com/albums/q251/datzenmike/motorLwaterpump.jpg[/img]"] L on left Z on right. Z has slightly larger fan blades. http://i138.photobucket.com/albums/q251/datzenmike/motorclutchfansLarge.jpg[/img]"] Not sure how many blades are on the non-clutch fan... four? I'm pretty sure they move more air. The Z ones move more water and air. Both are designed to slip at high speed where there is plenty of air flow and they aren't needed. I have a Z water pump for the flow and just cut the clutch part off and have an electric fan. Quote Link to comment
slodat Posted October 22, 2008 Report Share Posted October 22, 2008 Is there a non-clutch Z2x water pump? Quote Link to comment
datzenmike Posted October 22, 2008 Report Share Posted October 22, 2008 (edited) I have seen one on a Z22 but assumed it was swapped on when the original pump or clutch failed. Most if not all Nissans after mid '70s have the clutch fan. I imagine they (clutch type) are standard equipment and doubt if you could even ask for a regular one. If there was a 720 truck without it I would guess it would be the Dual tire Cab/Chassis option. It's for fleet use with a cube van box or motor home on the back and would NOT want the fan slipping at high speed/throttle. Maybe? Edited October 22, 2008 by datzenmike Quote Link to comment
