Hix1985 Posted May 31, 2016 Report Share Posted May 31, 2016 I need some help on a U60 head that I'm thinking of buying that has been shaved, the head is 4.243 thick at the center and varies no more than 3 thousandths from that at either end. 4.240 rear and 4.244 front. Is this head still ok to use? Quote Link to comment
banzai510(hainz) Posted May 31, 2016 Report Share Posted May 31, 2016 Thats a round exhaust port head. I think its flat enough. 1 Quote Link to comment
Hix1985 Posted May 31, 2016 Author Report Share Posted May 31, 2016 Ok thanks, just what I needed to know. Quote Link to comment
datzenmike Posted May 31, 2016 Report Share Posted May 31, 2016 If you are thinking of running this on an L16 it will drop your compression to 7.3... not a good idea. It's made for an L18 or L20B U60 is the same as a U67 (just earlier model) isn't it Hainz??? Square port, I'm pretty sure.. Stock head thickness is 4.248" I believe. Quote Link to comment
Hix1985 Posted May 31, 2016 Author Report Share Posted May 31, 2016 I'm on putting it on to a L20b, Got z22 crank ordering ka24e pistons off ebay, and just needed the head to finish it out. Then the little things like head gasket, I think a Z24 water pump,manifold, carbs you know the little stuff. :blush: Quote Link to comment
racerx Posted May 31, 2016 Report Share Posted May 31, 2016 I could be wrong but i thought i read somewhere that u60 head is rare and if the head was shaved at 2.4 as he stated, is it okay to use 2 gaskets? And since it will drop his compression, will it b good for turbo set up. Im learning too. Quote Link to comment
banzai510(hainz) Posted May 31, 2016 Report Share Posted May 31, 2016 never heard of 2 gaskets L20b block.? KA pistons are what 87mm? then OK if more then that its. Use a L series head gaskets is going to be in the bore unless you use a Z series gasket Why not get a Z22/24 block Quote Link to comment
Stoffregen Motorsports Posted May 31, 2016 Report Share Posted May 31, 2016 I have seen U60 heads with small chambers and square ports. I always thought they came on imported L18's. Quote Link to comment
Hix1985 Posted May 31, 2016 Author Report Share Posted May 31, 2016 never heard of 2 gaskets L20b block.? KA pistons are what 87mm? then OK if more then that its. Use a L series head gaskets is going to be in the bore unless you use a Z series gasket Why not get a Z22/24 block KA piston are 89mm, I have seen on here and other places people had made L series head gasket for 89mm bore. Thats how you get the LZ2.3 big bore. I live in Ohio and if you find z22 block they want way to much for it. like $400plus just for the block crazy :sick: Quote Link to comment
datzenmike Posted June 1, 2016 Report Share Posted June 1, 2016 I need some help on a U60 head that I'm thinking of buying that has been shaved, the head is 4.243 thick at the center and varies no more than 3 thousandths from that at either end. 4.240 rear and 4.244 front. Is this head still ok to use? I could be wrong but i thought i read somewhere that u60 head is rare and if the head was shaved at 2.4 as he stated, is it okay to use 2 gaskets? And since it will drop his compression, will it b good for turbo set up. Im learning too. He said 4.240 and 4.244 so barely 0.008" at the #4 cylinder down to 0.004" on the front. The LZ23 made with KA24E pistons has a compression of around 9.9 so he has plenty. I'm not a fan of low compression turbo engines. Unless boosting all the time it's a low compression engine. With 9.9 you can carve out some around the valves to unshroud them. Quote Link to comment
Hix1985 Posted June 1, 2016 Author Report Share Posted June 1, 2016 He said 4.240 and 4.244 so barely 0.008" at the #4 cylinder down to 0.004" on the front. The LZ23 made with KA24E pistons has a compression of around 9.9 so he has plenty. I'm not a fan of low compression turbo engines. Unless boosting all the time it's a low compression engine. With 9.9 you can carve out some around the valves to unshroud them. Hey Mike to get the 9.9 compression is that with a 1.2mm gasket? Quote Link to comment
datzenmike Posted June 1, 2016 Report Share Posted June 1, 2016 Yes. One point two is the crushed gasket thickness. Z22 crank, Z22 or L20B rods and KA24E pistons with an open chamber 45.3cc head. With 9.9 feel free to do a little combustion chamber grinding to unshroud around the valves. Quote Link to comment
banzai510(hainz) Posted June 1, 2016 Report Share Posted June 1, 2016 Most L series head gaskets are barely 85mm and I have some Durapro from Australia thast are 87mm bore. 89 I think your going to have to use a Z series gasket look up olddatsuns.com the tech section. Theres a writeup soemwhere on what to do. 1 Quote Link to comment
Hix1985 Posted June 1, 2016 Author Report Share Posted June 1, 2016 Found Felpro head Gasket that says its for l20b 89mm bore https://www.californiadatsun.com/head-gaskets/datsun-510-620-610-720-l20b-felpro-head-gasket.html Quote Link to comment
datzenmike Posted June 1, 2016 Report Share Posted June 1, 2016 Check it. The 'fire ring' must not be protruding into the combustion chamber or it will erode away and fail. You can use a Z24 and add several holes using your old L20B gasket. Trim the front off that seals the timing cover and use the old one. Quote Link to comment
Hix1985 Posted June 1, 2016 Author Report Share Posted June 1, 2016 Thanks Mike. Quote Link to comment
banzai510(hainz) Posted June 1, 2016 Report Share Posted June 1, 2016 never seen this Felpro gasket before stating 89mm bore. Didn't know there is enough demand to warrant manufacture of this. The Nissan motorsport was the one to get when going overbore. BUT IF THIS IS FOR REAL then its a good deal at 30$ but the Nissan ones are still better made. I WOULD ASK THIS GUY FIRST!!!!!!!!!! Quote Link to comment
Stoffregen Motorsports Posted June 1, 2016 Report Share Posted June 1, 2016 Use a Z24 gasket and trim the front to fit the cover, also depending on the gasket (some are different) you may need to punch a water coolant hole in the rear of the gasket. Use a L20B gasket as a comparison to help you figure out which holes need to be cut. For punching holes, I use a gasket punch, or you can make one by sharpening the end of a small piece of tubing. For the trimming of the front of the gasket, I use tin snips. Apply lots of grey or black (right stuff) silicone to the gasket surfaces on the front where the head meets the front cover. Quote Link to comment
Hix1985 Posted June 1, 2016 Author Report Share Posted June 1, 2016 Well I called about those head gaskets and they will not work, they will work up to 88mm bore. Quote Link to comment
