fisch Posted May 31, 2016 Report Share Posted May 31, 2016 This seemed like a clean simple solution since getting the fittings on those tubes out can be tough. An eyesore gone, much happier. I went for least frustration possible. Sure, an extra step 'tapping', but worth it to not wrestle with those fittings! It was actually a pleasure to do this rather than cussing at it with bleeding knuckles. Step 1: Step 2: Step 3: Step 4: Step 5: Step 6: Step 7: 1 Quote Link to comment
Rick-rat Posted May 31, 2016 Report Share Posted May 31, 2016 I took my manifold off and when you heat the fittings red hot they come out pretty easily, was able to remove the entire tube. Those fittings are not pipe thread, put in metric bolts and cut the head off the bolt flush with the manifold Quote Link to comment
Laecaon Posted May 31, 2016 Report Share Posted May 31, 2016 Why does the dewalt drill have a carbon fiber handle? Also, next time try tapping with a drill. Its fun, and only sometimes results in a broken tap... Quote Link to comment
datzenmike Posted May 31, 2016 Report Share Posted May 31, 2016 I removed the tubes completely so they are not in the exhaust ports at all. They reach almost to the valve guide. Them popped these pipe plugs in... Quote Link to comment
