Datsundude123 Posted May 3, 2016 Report Share Posted May 3, 2016 Question #1 does anyone have a wiring diagram for a 77 l20b coil to resistor and resistor to electronic distributor? hat would be awesome!#2 my friend Nate took my batter out because his battery was dying and when he put his battery in my truck he swapped the terminals so when I went to crank it over it started smoking I little bit and sparking! Now I'm getting no spark from my coil! Do you think something got shorted out and if so what was it?Ah and yes I'm going to beat his stupid ass! 1 Quote Link to comment
datzenmike Posted May 3, 2016 Report Share Posted May 3, 2016 The '77 didn't have electronic ignition (unless you are in California) The '77 has points and a coil and ballast. There will be no diagram of what you are asking for. Easiest thing is to get an EI coil and wire it in this way.... Battery polarity backwards? SMH. Nate is an idiot so stay away from him. Now you won't have spark and it could be anything Almost anything electronic could be burned out when you turned the ignition on... alternator or external regulator EI dizzy if you have one fusible links fuses wires in the harness. I guess start from the beginning and see what does work and find out what does not. 1 Quote Link to comment
Datsundude123 Posted May 3, 2016 Author Report Share Posted May 3, 2016 The '77 didn't have electronic ignition (unless you are in California) The '77 has points and a coil and ballast. There will be no diagram of what you are asking for. Easiest thing is to get an EI coil and wire it in this way.... Battery polarity backwards? SMH. Nate is an idiot so stay away from him. Now you won't have spark and it could be anything Almost anything electronic could be burned out when you turned the ignition on... alternator or external regulator EI dizzy if you have one fusible links fuses wires in the harness. I guess start from the beginning and see what does work and find out what does not. Ok and I got a new electronic distributor with Cali imissions 1 Quote Link to comment
banzai510(hainz) Posted May 3, 2016 Report Share Posted May 3, 2016 You got to be kidding me!!!!!!!!!!!!!!!!!!! Battery backwards. Seems like Datsun newbies always do this. One of the last 510 I workrd on was this wayalso. ck for power at the coil wire + side and see if lights ectt work and ck the fuses Sale the motor for 100$ and dump the truck what? I said to myself Im not writing anymore. You just sucker playing us. nobody can be this dense 1 Quote Link to comment
flatcat19 Posted May 3, 2016 Report Share Posted May 3, 2016 Best piece of advice you'll ever get...stop letting people touch your car. Datsundude needs to change his screen to datsundud. 1 Quote Link to comment
datzenmike Posted May 3, 2016 Report Share Posted May 3, 2016 You know they used to make the terminals on batteries different sizes so you can't put them on backwards. 1 Quote Link to comment
Datsundude123 Posted May 3, 2016 Author Report Share Posted May 3, 2016 You got to be kidding me!!!!!!!!!!!!!!!!!!! Battery backwards. Seems like Datsun newbies always do this. One of the last 510 I workrd on was this wayalso. ck for power at the coil wire + side and see if lights ectt work and ck the fuses Sale the motor for 100$ and dump the truck what? I said to myself Im not writing anymore. You just sucker playing us. nobody can be this dense Lol it wasn't me that did it it was my friends friend Nate that did it! 1 Quote Link to comment
Datsundude123 Posted May 3, 2016 Author Report Share Posted May 3, 2016 Best piece of advice you'll ever get...stop letting people touch your car. Datsundude needs to change his screen be to datsundud. I wasn't even there! 1 Quote Link to comment
datzenmike Posted May 3, 2016 Report Share Posted May 3, 2016 my friend Nate took my batter out because his battery was dying and when he put his battery in my truck he swapped the terminals so when I went to crank it over it started smoking I little bit and sparking! Now I'm getting no spark from my coil! Do you think something got shorted out and if so what was it? Lol it wasn't me that did it it was my friends friend Nate that did it! The other thread was painful enough. Now you have help fucking things up? Seventeen pages and it's now worse than it was. Chalk this up to life lessen not learned and start taking the bus when you go out.. 1 Quote Link to comment
flatcat19 Posted May 3, 2016 Report Share Posted May 3, 2016 For sale ad in 3...2... 1 Quote Link to comment
Rick-rat Posted May 3, 2016 Report Share Posted May 3, 2016 Why not merge all his threads into one FML thread 3 Quote Link to comment
flatcat19 Posted May 3, 2016 Report Share Posted May 3, 2016 Best post ever! Wait...all of this mess will just end up in Insomniacs. 1 Quote Link to comment
hobospyder Posted May 3, 2016 Report Share Posted May 3, 2016 Why not merge all his threads into one FML thread no fml threads it's against the rules 1 Quote Link to comment
