Eagle_Adam Posted March 28, 2016 Report Share Posted March 28, 2016 I need more of these The flat visble portion is Aprox 1/2 in across Would prefer black but I still have paint left so I can make any color work Soooo... Part numbers? Supplier? Direct link to buy get you extra internet points ;) Quote Link to comment
MicroMachinery Posted March 28, 2016 Report Share Posted March 28, 2016 Like these? Get 'em at Napa. 1 Quote Link to comment
Eagle_Adam Posted March 28, 2016 Author Report Share Posted March 28, 2016 Bingo :) Thank u Quote Link to comment
Skib Posted March 28, 2016 Report Share Posted March 28, 2016 There are loads of variety in those, I have drawers full of different stuff at work. Quote Link to comment
Eagle_Adam Posted March 28, 2016 Author Report Share Posted March 28, 2016 I figured there was, but it was late and I was lazy :/ Quote Link to comment
Skib Posted March 28, 2016 Report Share Posted March 28, 2016 if you have trouble finding one, take some measurements and I can compare to work stuff and get you a PN 1 Quote Link to comment
MikeRL411 Posted March 31, 2016 Report Share Posted March 31, 2016 Toyota and late Nissans have this "type" fastener but with a twist. They have center "posts" that poke above the flange when installed. You press them flat to secure them. When you must remove them [as you certainly will] you depress the center post and the fastener releases and is reusable. Cheap and reusable! I have seen Black and Dark Brown, so there must be other colors available. Quote Link to comment
KELMO Posted April 2, 2016 Report Share Posted April 2, 2016 Where does it go on the vehicle (or what trim part does it hold on) I can try and get you an OEM # if you like. Quote Link to comment
Eagle_Adam Posted April 10, 2016 Author Report Share Posted April 10, 2016 They hold the panels in places that are behind the seats So far the napa I stopped at and an Autozone havnt had anything in the same style, may be mcguyvering a solution from newer style fasteners like Mike said but I'll always take a part # ;) Quote Link to comment
bananahamuck Posted April 11, 2016 Report Share Posted April 11, 2016 Showing results for selected store: 12050 SW Canyon Rd 97005 http://www.napaonline.com/napa/en/search/?text=BK+6651384 Definitely give them a ring before rolling ,, but you never know ,, maybe it's the one time the internet was correct. :lol: Quote Link to comment
Eagle_Adam Posted April 11, 2016 Author Report Share Posted April 11, 2016 That's about as much of a "silver spoon" answer as I could ever hope for ;) Thanx Nanner 1 Quote Link to comment
Skib Posted April 12, 2016 Report Share Posted April 12, 2016 I think I have one of those in my closet actually. Ill see if it has clips lolol Quote Link to comment
Eagle_Adam Posted April 12, 2016 Author Report Share Posted April 12, 2016 I need close to a dozen ;) Quote Link to comment
Skib Posted April 13, 2016 Report Share Posted April 13, 2016 no clips. but do take a micrometer and measure these points for me. and I will get you a part number you can use at Napa. 1 Quote Link to comment
Eagle_Adam Posted April 21, 2016 Author Report Share Posted April 21, 2016 Like these? Get 'em at Napa. Like this Skib :p Quote Link to comment
Skib Posted April 22, 2016 Report Share Posted April 22, 2016 we have tons of sizes in that style, grab some measurements and Ill check em against the ones I have. Quote Link to comment
Skib Posted April 22, 2016 Report Share Posted April 22, 2016 I can get you the Napa PN Quote Link to comment
bananahamuck Posted April 22, 2016 Report Share Posted April 22, 2016 Skib ...... For fucks sake!! The,,,,,,,, NAPA,,,,,,,,,,,part ,,,,,,,,,,,,,,,,,,,,,,number,,,,,,,,,,,,,,,,,,,,,,, is ,,,,,,,,,,,,,,,,,,,,,,,,,,,on ,,,,,,,,,,,,,,,,,,,,,,the ,,,,,,,,,fucking,,,,,,,,,,,,,,,,,,,,,,,,,bag. It is 665-1348 ie.. Like these? Get 'em at Napa. Showing results for selected store: 12050 SW Canyon Rd 97005 http://www.napaonline.com/napa/en/search/?text=BK+6651384 Definitely give them a ring before rolling ,, but you never know ,, maybe it's the one time the internet was correct. :lol: Like this Skib :P Quote Link to comment
Skib Posted April 22, 2016 Report Share Posted April 22, 2016 There is more than one size for that style......... Quote Link to comment
Eagle_Adam Posted April 22, 2016 Author Report Share Posted April 22, 2016 Couldn't find my micrometer, will a tape measure get close enough for ya Skib? Quote Link to comment
Eagle_Adam Posted May 20, 2016 Author Report Share Posted May 20, 2016 Well I finally made it to the point where I needed a clip solution So I decided that the hard way should be the route I try first..... And bought these vvvvv It's a 2 piece upgraded version of the originals! Or so I thought ;) Long story short I ended up at napa referencing the PN Micro posted Perfect match and the right color ! Quote Link to comment
