poopypants720 Posted February 23, 2016 Author Report Share Posted February 23, 2016 Just mount the radiator lower, that is what I would do and have done in the past. tried it. Still not gonna fit inside the shroud I'm a fan of 92-95 Ford Taurus. Two speed, high cfm, should fit that radiator ok. Also early 2000s Ford focus dual fan assemblies have a reputation for being high cfm quality units. what's the ideal controller since its two speed? And do most controllers come with an inline temp sensor? so what was ther fix? well, I replaced the timing cover gasket and used a sealant and rtv as specified, then I torqued down the head bolts in order again... So far so good... Just hope there isn't a recurrence... Spent over 3x what this head gasket replacement should have cost me . Quote Link to comment
Lockleaf Posted February 23, 2016 Report Share Posted February 23, 2016 Guy set the controller up in a couple of different ways. For one you can run two different temp sensors each one controlling one fan speed. The other most common is to have a temp controller running the main fan speed and set up the secondary on a switch for just when it gets super hot. And yes any controller you buy should come with some kind of temp sensor there are a variety of different styles and those affect cost on them Use of these fans is pretty common in the off-road world. A little bit of Google searching should offer you a variety of ways that guys have set these up. Particularly on off road vehicles 1 Quote Link to comment
poopypants720 Posted February 24, 2016 Author Report Share Posted February 24, 2016 Figure cooling is imperative when your running high rpms in low gearing, but not going all that fast to really move air across the radiator... Quote Link to comment
poopypants720 Posted February 24, 2016 Author Report Share Posted February 24, 2016 Can I also pull the fan clutch off the water pump? Saw the 280zx had the same pump, but no clutch, but don't know where to find the pulley that mounts to the pump and they really aren't common in my junk yards here... Quote Link to comment
84720FourWheel Posted February 24, 2016 Report Share Posted February 24, 2016 It's a pain. The pulley is the inner race for the fan clutch bearings. You have to get the outer race to deform enough to get the ball bearings out. Then it will come off. Easier said than done. Quote Link to comment
Lockleaf Posted February 24, 2016 Report Share Posted February 24, 2016 L series pump pulleys should work I would think. Even early Z series had no fan clutch actually, so you could get a z22 water pump and pulley as be set I think Quote Link to comment
poopypants720 Posted February 26, 2016 Author Report Share Posted February 26, 2016 What happens if I take a hack saw and just cut right behind the fan clutch? Would the entire pulley assembly come off? Only asking cause after comparing a bit, the dome on the pulley is actually taller for the clutchless water pumps that if I were to be able to just remove the clutch from the pulley altogether... N I just picked up a ford focus dual fan n to get it to fit with my 3" thick, 3 core radiator and it together, I'll need about 5.5"-7" of clearance from the mounting@the front frame, to the front of the engine in order to make it fit... Depending on where the pulley lies between the two fans. Quote Link to comment
84720FourWheel Posted February 26, 2016 Report Share Posted February 26, 2016 It's a press fit pulley, so I don't know that I'd recommend cutting off half of the mounting area. Like I said, it's easiest to bust out the bearing cage, drop out the bearings, and it'll just pull off. 1 Quote Link to comment
datzenmike Posted February 26, 2016 Report Share Posted February 26, 2016 Can I also pull the fan clutch off the water pump? Saw the 280zx had the same pump, but no clutch, but don't know where to find the pulley that mounts to the pump and they really aren't common in my junk yards here... I cut the clutch apart to expose the bearing then sliced it up in pieces. Likely just removing the bearing will give you the room you want but you can trim the shaft as well. Stay at least 3/16" away from the pressed on pulley. 1 Quote Link to comment
84720FourWheel Posted February 26, 2016 Report Share Posted February 26, 2016 I've got about 6 inches between the core support and the end of the pulley. 2 Quote Link to comment
poopypants720 Posted February 27, 2016 Author Report Share Posted February 27, 2016 in case you guys were interested http://community.ratsun.net/topic/68808-affordable-and-effective-electric-fan-conversion/?view=getnewpost 1 Quote Link to comment
Lockleaf Posted February 27, 2016 Report Share Posted February 27, 2016 Glad to see one of my fan suggestions fit so well. Very nice setup you put together 2 Quote Link to comment
poopypants720 Posted February 28, 2016 Author Report Share Posted February 28, 2016 Was mainly looking at the Ford Taurus fan... But our radiators aren't even close to tall enough to effectively use one... So then moved into the Ford contour dual fan as many also mentioned it in the same threads as the taurus fans... Close to the same size as our radiators, but the first yard I found one at wanted $75 when it's $99 from rockauto(ummm, no)... So wound up where I knew I'd find something...the biggest yard in my area, and sadly enough, they are closing! Only good thing is, until the 29th everything is half off! So the first contour I walked up to was already scavenged, the next one was a crap single fan setup on a 4cyl, then I turn around and see the Ford focus! I was like, wait, Lock said those were decent movers! It was still there, in good condition and super easy to pull. Only $33! The rest of the setup was easy to piece together also and has become renown for its reliability and used across multiple years and vehicles, so it's cheap to source. Quote Link to comment
Lockleaf Posted February 28, 2016 Report Share Posted February 28, 2016 I hadn't ever seen the Volvo relay or the bmw dual temp sensor before. I'm totally stealing your setup for myself. 1 Quote Link to comment
poopypants720 Posted March 1, 2016 Author Report Share Posted March 1, 2016 I hadn't ever seen the Volvo relay or the bmw dual temp sensor before. I'm totally stealing your setup for myself. Hah! It works, why not? Thanks for helping me out with a starting point! Quote Link to comment
