Michael Rankin Posted December 15, 2015 Report Share Posted December 15, 2015 OK, I got lots of help for installing aluminum brake drums, now I want to install new rear wheel bearings. Since you guys have done this before, what do I need to do to remove the hubs to get at the bearings ? I have all the brake parts off, backing plate is loose, what's mext ? thanks Michael Quote Link to comment
KoHeartsGPA Posted December 15, 2015 Report Share Posted December 15, 2015 510 suspension forum ;) 1 Quote Link to comment
Draker Posted December 15, 2015 Report Share Posted December 15, 2015 You first start by rounding up all your favorite swear words. Then put them somewhere where they are easy to access. You'll need them. 4 Quote Link to comment
Ratwagon1600 Posted December 15, 2015 Report Share Posted December 15, 2015 510 suspension forum ;) This ^^^^ Or maybe DM will be nice enough to move it to the appropriate sub forum. Quote Link to comment
MicroMachinery Posted December 16, 2015 Report Share Posted December 16, 2015 I would have installed the wheel bearings before the aluminum drums. More efficient. Quote Link to comment
thisismatt Posted December 16, 2015 Report Share Posted December 16, 2015 Step one, remove entire control arms from vehicle. Quote Link to comment
demo243 Posted December 24, 2015 Report Share Posted December 24, 2015 Grab a case of beer, all those swear words mentioned above, a really long pipe to extend your breaker bar and a big socket (i think 27mm)…, a bearing press, a dremel and get ready for some fun. Can be done on the car, might be easier with the arms off. There are a few write ups around. Don't mess up the threads on the stub axles when your trimming the lock nut. And the torque spec is the higher one… ~200 ft/lbs or something like that. Quote Link to comment
