datzenmike Posted October 13, 2015 Report Share Posted October 13, 2015 Avoid ever running out of gas again. It stirs up and disturbs sediment everywhere, specially in the float bowl. Could be part blocked primary jet. Could just be a few drops of water which is heavier than gas doing the same thing... usually this clears out by driving it. Take a plug out. If strangely clean and white the jet is blocked and running lean. 1 Quote Link to comment
Three B's Racing Posted October 13, 2015 Report Share Posted October 13, 2015 I'm thinking is it possible you have a float that is slowly filling with fuel causing a overly high fuel bowl dumping gas into the carb which would explain these symptoms. When you get it to idle ok slowly run your hand over the top of the car chocking it off, if the idle speeds up you have a vacuum leak if you have a leak of a different type. Also check under you're distributor cap and make sure you don't have any arc burns leading from one terminal to another this will also cause a lot of these symptoms you've described. 1 Quote Link to comment
Motschrocker Posted October 13, 2015 Author Report Share Posted October 13, 2015 I pulled a plug today and it is white so im guessing mike is right that a jet is blocked and leaning it out. What is the easiest way for me to clean this out? Quote Link to comment
banzai510(hainz) Posted October 13, 2015 Report Share Posted October 13, 2015 try the mexican tune up. Rev the shit out of the engine then put a rage over it and maybe it will suck the dirt thru. or suck the dirt out of the rag into the carb Quote Link to comment
Motschrocker Posted October 13, 2015 Author Report Share Posted October 13, 2015 Ha ha not far from what i did. I just tapped on the side of the carb with the end of a screw driver and could hear when it cleared up. She is running good again. Thanks for all the input getting this thing going. I should try and let this thread come to a close. Quote Link to comment
banzai510(hainz) Posted October 14, 2015 Report Share Posted October 14, 2015 could be dirt in float bowl floating around covineering up then is fine. But I think you would be able to see it from the front glass the condition. anything with a exposed gas tank has more chance od dirt rust issues My 521 dirt/water gets in from the fuel hose in the wheelwell and runs down inside.(privios owner told me this) hes gas tank would actually fill up when it rained. So i run 2 filters and change dthem more often. 510s dont have this proplem as the tennk is in the trunk and fuel opening is on side and really not water gets to it. Quote Link to comment
datzenmike Posted October 14, 2015 Report Share Posted October 14, 2015 I have actually taken the jets out with the carb on the manifold but much much easier if it is off. The jets are got at by removing the two plugs on the outside of the carb body just below the glass front. Again this is not a stock carb so... ????? Quote Link to comment
Motschrocker Posted October 15, 2015 Author Report Share Posted October 15, 2015 Thanks guys. Things running okay right nkw. Not perfect. My vacuum gauge bounces a little between 15 and 20 at idle. Most of my plugs look good except for the number 2 cylinder. It is a bit black. Maybe a bad seal? Quote Link to comment
