btd19m Posted September 5, 2015 Report Share Posted September 5, 2015 pics up front. lifed locked sased. 64000km rust free Quote Link to comment
btd19m Posted September 5, 2015 Author Report Share Posted September 5, 2015 Posted Today, 12:28 AM so till last year it sat at a dealer in new condition still extremely close to new. need to know what to watch for what to do first and so on. front end was just done too. diff is solid axle (factory) has a 2 inch lift. no blocks though. rear end is unknown. fluids oils liq's will be done. will drain the tank. rust free for now. (where will rust form first?) will bleed brakes and such if needed. needs a handbrake cable and a radiator overflow bottle and that's it motor wise. maybe a webber for good measure (z24 is weber compatible right?) Quote Link to comment
Rjawm Posted September 5, 2015 Report Share Posted September 5, 2015 You all must have a very different definition down under of what a "mint barn find" looks like. 1 Quote Link to comment
Lockleaf Posted September 5, 2015 Report Share Posted September 5, 2015 Minus the interior bed damage, it's pretty damn clean. You said it's factory SAS? What axle is underneath the front end? Cool truck man Quote Link to comment
datzenmike Posted September 5, 2015 Report Share Posted September 5, 2015 Agreed. If stored in a barn for 20 years expect some dirt and anything that age would affect. Brakes might have seized, gas in tank might be iffy, any lubricants or coolant would need changing in the near future. Better hope it had antifreeze in the rad or it will be very rusty by now. Tires and hoses should be ok if stored out of the light but sitting flat or on the same side they may be permanently lumpy. Hopefully the windows were closed and the chickens didn't get in there. Quote Link to comment
btd19m Posted September 6, 2015 Author Report Share Posted September 6, 2015 She started first turn with some new fluids and battery plus filters. She's 3 foot off the ground at the arch. Need to know if that's nomal or if it's got a big lift or something. My dual cab is 1/4th of that. And my f150s 35s would almost clear. Quote Link to comment
btd19m Posted September 6, 2015 Author Report Share Posted September 6, 2015 Ohh almost forgot washed her. Rust free everything but tub it has a spot at the edge. Crack in the frame isn't a crack it's where the first owner sealed a bash plate to the body with a welder and put a serous weld on it Quote Link to comment
btd19m Posted September 6, 2015 Author Report Share Posted September 6, 2015 some more pictures. 2 of them can be inorged (80-81 dash pics) http://imgur.com/fnkXCaL,qQMTQLe,wpJA5Oz,7UfMUXd,n0FbIY2,xtGrKsI,zhP1h4H,h85m51T,MdWsGIR,6DbPw44,jmOYKj8,PjvH3OT,YIRdM7L,dNkdtyp,0MMeGKn,0ZdfmJh,tGzfS95,0ct5nSn,QTU5Jyt,tykUqmR,9RFq12k,YH0UQAt,AOh2TS1,u3BbuGm,lfS2E28,qMQa8Qp,lvAuVnS,FjkM6XG,vjofZEY,MbnQIgX,psrg0Rr,eWPbeHt,CFz1IgD,SaOdtzr,faW5g0m,Ak1rqj4,hrNdc0j,FCLPpYy,9nMT4Lm,BDEQMYQ,nWw8w52,00F47oK,JnINkMe,EQQJ4PL,M38rITB,os02JIU,ip4KrP9,gfCyiEt,TWuEsqC,ax3iWSU,2kb6PXT,wiHKw9t,kmsZLFv,tEZoXMW,4tPqhJT,1B7NrOf,lNT5nxa,jF84fbs,IgABSKL,6H4c7cl,LRjapgV,E6zd7eC,wgM6Tfn,25FYOFY#0 Quote Link to comment
Rhino13 Posted September 6, 2015 Report Share Posted September 6, 2015 The running gear looks stock to me, and the height in the front looks stock also, possibly an add a leaf kit in the rear. Are you planning to do a solid axle up front or do you think that is a solid axle? It currently has independent front suspension, that's why you have CV axles on either side of the differential. It's cool seeing the small differences from US models like the wiper switch and the tiny corner bumpers in the rear, let's see it after its bath! 1 Quote Link to comment
btd19m Posted September 7, 2015 Author Report Share Posted September 7, 2015 after a bath. thought hub was stuck. turns out they both spin the opposite way to normal my girls together. (red and yet as named 4x4) (wire out the door is from the speakers till i work out why the old owner welded up the factory speaker holes) Quote Link to comment
Sealik Posted September 7, 2015 Report Share Posted September 7, 2015 She started first turn with some new fluids and battery plus filters. She's 3 foot off the ground at the arch. Need to know if that's nomal or if it's got a big lift or something. My dual cab is 1/4th of that. And my f150s 35s would almost clear. That's "nomal" height and 35s won't clear. Wouldn't look as 'high ' if you slapped some fender flares on it..... It's cool seeing the small differences from US models like the wiper switch and the tiny corner bumpers in the rear, let's see it after its bath! .....and the cab vents . Quote Link to comment
Rhino13 Posted September 8, 2015 Report Share Posted September 8, 2015 .....and the cab vents . US models came with cab vents, here is my first 720 in Oregon Quote Link to comment
Sealik Posted September 8, 2015 Report Share Posted September 8, 2015 US models came with cab vents, here is my first 720 in Oregon Looks like a pre '84........pretty sure all single cab 84+ US/Canada models had cab vents like this..... Quote Link to comment
Rhino13 Posted September 8, 2015 Report Share Posted September 8, 2015 Ah right, it's an 81, didn't think about that. Your truck is super clean Sealik! Quote Link to comment
btd19m Posted September 9, 2015 Author Report Share Posted September 9, 2015 mines an 84 4x4 my twin cab 2x4 (81) has the same vents. we never had 720s after 85 and they all had the same vents and such. my vin puts it as 8/84 from memory. Quote Link to comment
btd19m Posted September 10, 2015 Author Report Share Posted September 10, 2015 got a sort of plan. found a 3 inch lift kit (break lines and extended tortions and all inc rear shocks and rear blocks) going for 2.2k for my model. looking for a set of 25-30(?) inch mud tires. found a maker for the winch plate mine had with a much higher 17000 pound limit. and got a 13000 pound winch on layby looking at a set of lightforce 240 blitz. or rally 4000s as it turns out mine has nissan aftermarket spotlight wiring and all on a switch on the steering but no spotlights. (parker, low,high, spot) it does have a pretty dodgy towball. so that's got to go, considering a rear mounted winch as well. just in case. you know. stuff. today was my 21st. and my 5th year of having my drivers permit. can go turbo soon or motor swap without losing my drivers also looking at a set of underbody armour. we put it on a lot of cars here as it means when something hits the bottom it doesnt break things it just hits the 5mm steel plates Quote Link to comment
Gradyfest Posted November 17, 2015 Report Share Posted November 17, 2015 I like the little parcel tray on the passenger side, lol. That's actually probably a rare piece. The welded on rope ties like the 620s are interesting as well. 1 Quote Link to comment
Lockleaf Posted November 17, 2015 Report Share Posted November 17, 2015 We call that armor skid plates. I'm running a 3 inch lift and 31 inch tires. Anything smaller than 30 inches will look tiny under there, you will likely want something at least that size. And congrats on the birthday. Quote Link to comment
