Minesmith67 Posted May 7, 2015 Author Report Share Posted May 7, 2015 So what's the difference between the 36 and the 38 Quote Link to comment
datzenmike Posted May 7, 2015 Report Share Posted May 7, 2015 The 32/26 is a 32mm primary by 36mm secondary carb. It's known as a progressive carb with the secondary coming in as the primary opens above the 3/4? point. The The smaller primary gives good economy with the larger secondary for performance like passing on the highway. A good size for all 4 cylinder engines. The 38/38 is much larger and designed for larger displacement engines like 6s and small V8s. Both barrels open together so it drives best when 'stepped into' as the engine revs up. Slightly too large for most 4 cylinders and when gas economy isn't important. Quote Link to comment
84720FourWheel Posted May 7, 2015 Report Share Posted May 7, 2015 The 38/38 has 2 38mm barrels and IIRC is a synchronous carb. The 32/36 has one 32mm barrel and one 36mm barrel, and is a progressive carb. Synchronous=both barrels open at the same time Progressive=one barrel opens before the other. 2 Quote Link to comment
Minesmith67 Posted May 7, 2015 Author Report Share Posted May 7, 2015 Ok awesome I like progressive carbs anyway so I think I will go with the 36 Quote Link to comment
datzenmike Posted May 7, 2015 Report Share Posted May 7, 2015 Read carefully. The 32/36 is the progressive carb. Never over cam or over carb your engine. Better to have a smaller one and wish you had larger than to have the larger and wish it were the smaller one. The 38/38 has 2 38mm barrels and IIRC is a synchronous carb.The 32/36 has one 32mm barrel and one 36mm barrel, and is a progressive carb.Synchronous=both barrels open at the same timeProgressive=one barrel opens before the other. 1 Quote Link to comment
dogbolter Posted May 8, 2015 Report Share Posted May 8, 2015 I just got a 85 Nissan 720 4x4 it has the Z24 motor. Dies anyone have a vacuum diagram for it from a Chilton. And I wanna put a different carb on it what are your recommendations. HI mate... yeh got some links you might like... i got a 32/36 weber on mine and have done all sorts to it... ripped out the viscous fan and put in twin thermos , extractors, dual battery MSD leads haven't dynoed it yet... but i reckon i got at least 20 more HP out it just with these mods... Follow the links at Dyno Mule to see where i am going with it.. https://www.dropbox.com/s/4ldmc5nvvr30qvp/2015-05-07%2011.29.59.jpg?dl=0 https://www.dropbox.com/s/cvrijpqfr3jz3id/2015-05-07%2011.27.10.jpg?dl=0 https://www.dropbox.com/s/yvjegeythh3n48h/2015-05-07%2011.27.47.jpg?dl=0 check out this .... i am gonna do this next.. http://www.turbodatsun.com/Z24%20Dyno%20Mule.htm 1 Quote Link to comment
dogbolter Posted May 8, 2015 Report Share Posted May 8, 2015 Never give up this is what mine looked like for several years.. https://www.dropbox.com/s/sb9kvpfjv3ikub8/small_dam.jpg?dl=0 and Now https://www.dropbox.com/s/fqocyejlz9zw7ag/small_rh_bush.jpg?dl=0 https://www.dropbox.com/s/1zmno5espk1enek/smallLHInside.jpg?dl=0 https://www.dropbox.com/s/con67p3v6zb5z74/minibush.jpg?dl=0 here's a digital manual -- download them all to the same folder as the files are all lnter-connected https://www.dropbox.com/s/4l1env5yypjw66f/upsd21_truck_1989.pdf?dl=0 https://www.dropbox.com/s/fqhvdghgw3ax47x/d21_truck_1990.pdf?dl=0 https://www.dropbox.com/s/9ymw14nh67vmbh3/d21_truck_1989.pdf?dl=0 1 Quote Link to comment
datzenmike Posted May 8, 2015 Report Share Posted May 8, 2015 http://www.turbodatsun.com/Z24%20Dyno%20Mule.htm This is GREAT stuff. All Z24 owners rave about the weber carb swap. The Hitachi is more for economy and emissions. Finally some dyno data. 1 Quote Link to comment
dogbolter Posted May 8, 2015 Report Share Posted May 8, 2015 Yeh the guys name is Ben he lives over east some place.... he's working on getting an inter-cooler working with it as well once he finalises everything (The turbo kit is complete) i'm gonna get one ... i have an engine in my shed which i am gonna build for trubo.. wiseco rods... stroked crank... scoop out some piston-top meat to lower compression.... Blow the turbo thru the 32/36 etc.. it's gonna fly ... however--- i'm not really interested in speed i just want more power in the bush and for pulling out stumps LOL... oh yeh look at this... https://www.calmini.com/detail.php?b=1&m=4&t=3&p=916&n= I went to look at a house a few months back and had to get into 1st low 4wheel drive to get up the dam drive-way... shit it was steep... the little z24 didn't like it much so i reckon with the turbo and the reduction gears it will climb trees ... LOL 1 Quote Link to comment
Minesmith67 Posted May 8, 2015 Author Report Share Posted May 8, 2015 You have the hard body. I don't and can I see some pictures of your motor with all the mods 1 Quote Link to comment
Charlie69 Posted May 8, 2015 Report Share Posted May 8, 2015 Better to have a smaller one and wish you had larger than to have the larger and wish it were the smaller one. That what she said! LOL 2 Quote Link to comment
dogbolter Posted May 9, 2015 Report Share Posted May 9, 2015 Yep i'll upload a couple later tonight (Saturday) Quote Link to comment
Minesmith67 Posted May 9, 2015 Author Report Share Posted May 9, 2015 Awesome thanks Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 Pix of various mods... 1. 100 amp alternator 2. 32/36 dgva Weber 3. 9500lb Winch 4. Twin thermo Fans (From an australian AU ford falcon) 5. Dual Battery System 6. Manual choke weber has a micro-switch to activate a light in the cab to tell me if i left the choke on 7. Lokka Diff ready to go in 8. The dog assembled the diff ready to install 9.The center Dash 10. High-tensile alloy bash plate 11. Another diff shot 12. The Lokka assembled in the carrier 13. Note the winch controller to the right breings it up ouit of the dirt and water 14. The Diff in bits on the bench 15. Switch Block in cab for various Systems 16. a Little mod to the vacumm guage setup 17. Webers ae notorious for vacumm leaks this fixxes it 18. note the little tube stuck in the choke mechanism... it allows you to take the lid off the carby over and over to try diffferent Jets 19. how to hook up an auto idle advance for your when your thermos switch on and for aircon fast idle 20. The engine bay from the right 21. a closeup of the door 22. How to hook up the switch for the choke light 23. An r200 front Diff 24. An r180 front diff Note the housing difference Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 i'll do some more later .. it's mothers day here :) don't wanna upset the cook Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 Some pics of additions and mods. 1. The Dash Now 2. Toyota Celica seats Fitted ... i had to build raise platforms for them to bring them up 3" 3. In Cab Switch Block - i had to use my Dremel to cut out the plastic so the backs of the switches could recess into the dash 4. PSR Programmable Switching Relay for battery control it swings up for ease of access and programming 5. PSR in up position 6. Anderson Plugs for power outllet on all 4 corners 7. note the silver tube between the cowling and the black bracket its to mount the cowling OFF the radiator so it won't wear a hole in the radiator the catch-can is mounted on a checker -plate bracket which is rivetted to the cowling if you do this watch out that you use rivets of the right size else you will crack the plastic 8. Auxiliary Fuel pump mounted in the engine bay in series with the original supply this is needed to supply the weber at high revs 9. another shot of the PSR and another 10 Bullbar mounted and integrated with the bumper bracket 11. After-market Idler arm Brace 12. Re-built Cv Shafts 13. Chasis MOunted Winch 14. The resulting mounted winch Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 1. Recon Gear-box and diffs all painted Yellow 2. locker cutouts for the front wheel Caps 3. Wheels and Tyres 4. To remind me of the past 5. Now this is Kool Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 Parts to get for the Turbo Engine Mod I'd be happy to answer any questions about the mods above .. a bit of a tip might be to think carefully about what you are going to add or change then plan it as carefully as you can and make sure you have all the parts on hand else you might create other problems that might not have been necessary had time been taken to think it though. During my own work i had to have my Ute running the next day as i use it for work everyday. The Old Girl Work Horse She works her ass off Her ass fell off Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 I wish i had taken more pics during the rebuild .. but there you go everything is good in hind sight Quote Link to comment
dogbolter Posted May 10, 2015 Report Share Posted May 10, 2015 Oh yeh when you are fitting electrical stuff make sure you put fuses in every circuit as close to the battery as you can so that the fuse will blow before your wiring is damaged or worse still a fire breaks out. What i did was put in an extra fuse panel for the electrical stuff under the bonnet ... power that up after then get all your power of that then you have a fuse for every circuit. also make sure you have 100amp fuses between your aux battery and your battery controlled as well as between your battery controller and your main battery. With thermo Fans make sure you have each fan on its own relayed and fused circuit e.g run a given fan from a relay that has a fuse in line prior to the relay also watch that you plugs to the fan are good mine melted ... i did all my own wiring but had an auto-electrician put in a diode so the power from the fans would not feedback thru the various switched circuits ... e.g you need a circuit for the thermo switch, the manual switch, and the aircon switch to run all independent of each other because you need the fans for aircon, for temp control in isolation from aircon (when aircon is off) and for manual when both temp and aircon is off this is useful for 4x4ing also good if the thermo switch or relay fails as mine did on a few occasions.. remember you doing away with the mechanical cooling device. Quote Link to comment
720inOlyWa Posted May 15, 2015 Report Share Posted May 15, 2015 Post up the pictures. Z24 is a good engine A fine little engine! 2 Quote Link to comment
Minesmith67 Posted May 15, 2015 Author Report Share Posted May 15, 2015 Yeah I hope it is I'm going to get it tonight in washington in excited 2 Quote Link to comment
Minesmith67 Posted May 18, 2015 Author Report Share Posted May 18, 2015 So I just learned I need to replace the carb this sucks was hoping to hear her start up before I took her home. Damn 1 Quote Link to comment
Charlie69 Posted May 18, 2015 Report Share Posted May 18, 2015 Pull the spark plugs and post some pictures please. Quote Link to comment
Rhino13 Posted May 18, 2015 Report Share Posted May 18, 2015 So I just learned I need to replace the carb this sucks was hoping to hear her start up before I took her home. Damn Is it in too rough of shape or is it not firing? 1 Quote Link to comment
