Thisolddatsun Posted April 12, 2015 Report Share Posted April 12, 2015 I heard the 86 4x4 720 has the best disk brakes. My question is can I just swap the caliper and rotor over instead of doing the whole knuckle? I have a 81 4x4 and if I was to do this I would neee to change cv axles and Im not sure if the lengths are different or not but I know the width of the input shaft is bigger than mine. Is it the same off a pathfinder? I was thinking if the rotor is the same it should just go right on, right? 1 Quote Link to comment
datzenmike Posted April 12, 2015 Report Share Posted April 12, 2015 Well they are definitely an improvement but very unlikely to swap without swapping the complete knuckle. For one thing the later rotor is much wider and vented, the '81 is a dinner plate. The early D-21 Hardbody used the 720 front brakes and may be easier to find.The 720 up until Oct '82 pretty much reused the much older 620 disc brakes 1 Quote Link to comment
flatcat19 Posted April 12, 2015 Report Share Posted April 12, 2015 spindle needed. The spindle holds the caliper which is spaced properly to accommodate the rotor spacing. 1 Quote Link to comment
thisismatt Posted April 12, 2015 Report Share Posted April 12, 2015 spindle needed. The spindle holds the caliper which is spaced properly to accommodate the rotor spacing. Sounds like an assumption, though. Caliper can be offset on its own, and rotor hats can be different. I don't know the answer, but... 1 Quote Link to comment
flatcat19 Posted April 12, 2015 Report Share Posted April 12, 2015 Sounds like an assumption, though. Caliper can be offset on its own, and rotor hats can be different. I don't know the answer, but... Huh? Then how much guess will be involved find a rotor to fit where ever you decide place the caliper. Early 720 spindles are different parts than the later ones. Make life easy. Just get all or none. 1 Quote Link to comment
Thisolddatsun Posted April 12, 2015 Author Report Share Posted April 12, 2015 Huh? Then how much guess will be involved find a rotor to fit where ever you decide place the caliper. Early 720 spindles are different parts than the later ones. Make life easy. Just get all or none. I know the splines are different. It might not work if the cv axles are different lengths as well. 1 Quote Link to comment
flatcat19 Posted April 13, 2015 Report Share Posted April 13, 2015 I wasn't even thinking about axles. Just the spindles/hubs/rotors. 1 Quote Link to comment
Thisolddatsun Posted April 13, 2015 Author Report Share Posted April 13, 2015 I wasn't even thinking about axles. Just the spindles/hubs/rotors.If i was to do it I would take the whole knuckle and swap it ball joint to ball joint. I just would like to use 4 wheel drive. Dont really know how to work with the cv axles for splines and lengths. 1 Quote Link to comment
84720FourWheel Posted April 13, 2015 Report Share Posted April 13, 2015 You may have to swap over the later CV shafts. I'm not sure if they are different lengths, if they are you would need the differential cross member from the later model to move the diff, and possibly the other mount from the front. 1 Quote Link to comment
Seeker > 620 KC Posted May 29, 2018 Report Share Posted May 29, 2018 This long weekend was 40% off day at the local JY. I pulled 720 RWD spindles, rotors, hubs, and calipers for this upgrade. The hoses and ball joints were well worn so I left them in the yard. The rotors are pretty scaley but I took them and the rotors just to be safe, but found I could have left them both. New Raybestors clearance rotors were $11 each at RA, with shipping <$40 shipped, and my hubs appear to be identical, but still have to mike bearing races and spindles to be sure. Now that I want to buy pads, caliper kits, and hoses, I find there are multiple part numbers listed for RWD vehicles on RA? Very puzzled I went to nissanpartsdeal.com and found there were two different calipers made for 720's RWD, one by Nichirin, and one by Hitachi both with different part numbers. I also found there are two different calipers made for 4x4 by the same two companies. Now I don't know which parts to order. Anybody know how to tell the two manufacturers apart? Quote Link to comment
Thisolddatsun Posted May 30, 2018 Author Report Share Posted May 30, 2018 This long weekend was 40% off day at the local JY. I pulled 720 RWD spindles, rotors, hubs, and calipers for this upgrade. The hoses and ball joints were well worn so I left them in the yard. The rotors are pretty scaley but I took them and the rotors just to be safe, but found I could have left them both. New Raybestors clearance rotors were $11 each at RA, with shipping <$40 shipped, and my hubs appear to be identical, but still have to mike bearing races and spindles to be sure. Now that I want to buy pads, caliper kits, and hoses, I find there are multiple part numbers listed for RWD vehicles on RA? Very puzzled I went to nissanpartsdeal.com and found there were two different calipers made for 720's RWD, one by Nichirin, and one by Hitachi both with different part numbers. I also found there are two different calipers made for 4x4 by the same two companies. Now I don't know which parts to order. Anybody know how to tell the two manufacturers apart? you would have to know the year truck you pulled it off. 80-82 has style A. 83+ have style B. Along with the 4x4s have different styles i believe as well. You'd need to find out what year the truck was you took parts off of and go from there or even try your local parts place. Some parts its nice to get locally for this reason. Quote Link to comment
datzenmike Posted May 30, 2018 Report Share Posted May 30, 2018 I have Tokico listed as a maker. Quote Link to comment
