Mike808 Posted March 29, 2015 Report Share Posted March 29, 2015 Hi all, Ive been a lurker here for a while but recently picked up my first Datsun. Its a '71 510 wagon and I love it! Problem is, the car has a ka24e engine but the PO attached a 200sx ('81 I believe) ECU to the engine. The engine runs fine but it seems to be running rich. The PO said that he did this with plans to turbocharge in the future but Ive never heard of using another cars ECU for this. Anyways, I want to put the correct (240sx) ECU back on the car but I cant seem to find the wiring diagram for the 200sx ECU to splice on the correct ECU connector. Does anybody have a recommendation on where to go from here? The connectors are not the same and I am hesitant to start cutting wires without a diagram. Any help is appreciated. Thanks, Mike 1 Quote Link to comment
datzenmike Posted March 29, 2015 Report Share Posted March 29, 2015 bump to the top 1 Quote Link to comment
flatcat19 Posted March 29, 2015 Report Share Posted March 29, 2015 Get the part # off the ECU and post here. I doubt it has a different ECU unless the wiring is all hacked apart. Look up how to pull codes from the ECU. 1 Quote Link to comment
ggzilla Posted March 29, 2015 Report Share Posted March 29, 2015 It is from Kelvin's dime quarterly article. To use the 1981 200SX ECU it should be used with the 1981 200SX AFM. In any case it doesn't make sense because KAs come with a better ECU. Quote Link to comment
Mike808 Posted March 29, 2015 Author Report Share Posted March 29, 2015 Thanks all for the replys. The part # off the ECU thats in the car is A11-610 572. Google tells me its for a Z20e engine. I have the original ECU for the KA as well as the entire wiring harness for that car. Would it just be easier to rip out the wiring harness in the car and install the 240SX harness? Can this even be done? Quote Link to comment
datzenmike Posted March 29, 2015 Report Share Posted March 29, 2015 Yes an '80 California spec 5 speed. Better post a picture of your engine and the plug with the current ECU on it. This makes less than zero sense for doing. The '81 ECU won't work with the KA's sensors. In no way would the old technology Bosch batch fire fuel injection work with a turbo. Regardless..... Put the KA ECU, wiring and sensors in. But post those pictures first. Wouldn't be the first time someone thought they had one engine and they had something else. 1 Quote Link to comment
ggzilla Posted March 29, 2015 Report Share Posted March 29, 2015 > In no way would the old technology Bosch batch fire fuel injection work with a turbo. Except for 280ZX turbo. But yeas the non-turbo ECU won't work right with a turbo. 1 Quote Link to comment
Mike808 Posted March 30, 2015 Author Report Share Posted March 30, 2015 Alright, here are the pics. ECU label Engine harness Quote Link to comment
Icehouse Posted March 31, 2015 Report Share Posted March 31, 2015 OMG!!!!! Throw that bastard in the garbage. Get EVERYTHING off a S13 with a single cam, make sure you find a number 11 ECU don't forget the MAF. Wire it in and be happy. Who would do all that work to have a crappy ecu..... Doesn't make any sense. Dumping mega fuel in all the time isn't the answer for a turbo setup either. wow, just wow. 2 Quote Link to comment
Mike808 Posted March 31, 2015 Author Report Share Posted March 31, 2015 HAHA! Thanks all for the help and answers. Luckily I have the ECU and harness that came from the engine in the first place. Ive never done anything like messing with an engine harness but I guess now is as good a time as any to learn. Would you guys recommend one of the can/am boxes to wire it to the car? I honestly havent even checked to see if there is much of a wire harness outside of the engine harness. Cant imagine this car has very much else in the way of electrics. Quote Link to comment
datzenmike Posted March 31, 2015 Report Share Posted March 31, 2015 http://community.ratsun.net/topic/28097-canam-production-easy-wiring-boxes-for-efi-works-for-kas-srs-vgs-cas-and-more/ It's all here. Quote Link to comment
sycloned916 Posted April 3, 2015 Report Share Posted April 3, 2015 Hey I have a 510 at my house now with that set up running, you can check it out if you want in in sac to. Pm me for info. I can help wire it up, I have a harness for the better of the ecu's. Quote Link to comment
DrRocks0 Posted April 5, 2015 Report Share Posted April 5, 2015 I've dealt with that engine before. Its the bastard KA. Seriously finding MAF's and oxygen sensors for it are a nightmare. Friend of mine tried every part number under the sun then just pulled the motor and got another one. Good luck. Quote Link to comment
