Emilio's79620 Posted March 4, 2015 Report Share Posted March 4, 2015 Ok so my 79 is scaring me alittle the gas gauge is not reading all that right the kid I bought it from said full tank goes way pass the f and I'm alittle behind half I don't want to run out of gas because that's just dumb as f but I just want to know if there's a way to get it to read properly the temp gauge works Quote Link to comment
MikeRL411 Posted March 4, 2015 Report Share Posted March 4, 2015 Temporary rule of thumb so you don't run out of gas in the middle of an intersection or on the freeway. Dates back to the original VW bug which did not have a gas gauge [a "Good Lord" lever which when pulled up gave you about one more liter to find a gas station was the out]. Most vehicles have a gas tank sized so that you will get 200 miles in city driving or 4 hours of driving at open highway speeds [unless you are a speed nut] before you should start looking for a gas station. Hope you find and cure the base problem! Quote Link to comment
Draker Posted March 4, 2015 Report Share Posted March 4, 2015 Ok so my 79 is scaring me alittle the gas gauge is not reading all that right the kid I bought it from said full tank goes way pass the f and I'm alittle behind half I don't want to run out of gas because that's just dumb as f but I just want to know if there's a way to get it to read properly the temp gauge works Pull the fuel sending unit, clean and inspect. Quote Link to comment
Guest Rick-rat Posted March 4, 2015 Report Share Posted March 4, 2015 :poop: I thought that the E on the gauge meant enough Quote Link to comment
ggzilla Posted March 4, 2015 Report Share Posted March 4, 2015 full tank goes way pass the fthat is normal for every Datsun I've ever owned. 1 Quote Link to comment
datzenmike Posted March 4, 2015 Report Share Posted March 4, 2015 Carry a small gas container and stop worrying. It isn't going to run out just under the F. It runs out near E over 200 miles away. The sender probably just sticks near the top and doesn't read any higher, so what? Drive untill it runs out, dump your saved gallon in and refill right away. You should have 9 or 10 US gallons fit in it. Now you know you have the corretc amount even though the gauge may read low. What's important here is where it reads when it runs OUT. Full is full no matter what the gauge says. Quote Link to comment
rharm78 Posted March 6, 2015 Report Share Posted March 6, 2015 Whenever my truck is on E it usually only takes about 8.5 gallons and when I fill it up it goes past F aswell so yeah...... Quote Link to comment
datzenmike Posted March 6, 2015 Report Share Posted March 6, 2015 The '73-'78* 620 holds 12 US gallons. The long bed holds 17. The '79 620 holds 13 US gallons. * I think the '78 also holds the same amount of gas as the '79. Both '78 and '79 were the years when the tank changed and was mounted to the frame and not the bed. Quote Link to comment
