datO))) Posted February 7, 2015 Author Report Share Posted February 7, 2015 And when the parts "person" asks "what is a Datsun 411?" have[whatever]look for a Iszu [ Buick OPEL] set of points, they are the same JDM point sets. So I work at an auto parts store and pull the ople contact set. It doesn't Mach the the set I have in my A15 I'm just curious If there would be a better grade of points or brand if you will. For the A15 Quote Link to comment
RATDAT3 Posted February 8, 2015 Report Share Posted February 8, 2015 If you decide to get rid of the roof rack...let me know. Quote Link to comment
MikeRL411 Posted February 8, 2015 Report Share Posted February 8, 2015 So I work at an auto parts store and pull the ople contact set. It doesn't Mach the the set I have in my A15 I'm just curious If there would be a better grade of points or brand if you will. For the A15 The A15 is not the stock 411 engine. I am talking the R1600 Hitachi distributor. The "Opel" being built in Japan used the available Hitachi point system. 1 Quote Link to comment
datO))) Posted February 9, 2015 Author Report Share Posted February 9, 2015 Yeah after a bit of digging , I got a clue. They still didint like as if they would Mach the same "footprint " as the OEM set. But who knows. I'm still green at this. Im trying to fix my heater so it gets heat instead of cold air, temp gauge/fuel gauge regulater still not working. The list goes on and on. Never give up. Never sell 1 Quote Link to comment
datO))) Posted February 9, 2015 Author Report Share Posted February 9, 2015 If you decide to get rid of the roof rack...let me know. I will. 1 Quote Link to comment
MikeRL411 Posted February 9, 2015 Report Share Posted February 9, 2015 Yeah after a bit of digging , I got a clue. They still didint like as if they would Mach the same "footprint " as the OEM set. But who knows. I'm still green at this. Im trying to fix my heater so it gets heat instead of cold air, temp gauge/fuel gauge regulater still not working. The list goes on and on. Never give up. Never sell The instrument panel VR is a bimetal strip that operates as a "chopper" to regulate the voltage by making almost but not quite square waves of the 12 volt input and letting the thermal inertia of the meters smooth it all out. Most likely failure mode? Welded points. Try this to confirm. With the flat of your hand swat the instrument cluster top just in the center about twice. If the instruments respond then that's your answer. Swatting will get you some period of operation, but obviously the points are not perfect and are just waiting for an inopportune moment to weld again. Go to the "How To" section for a description of an electronic "Make or buy from me" write up on a replacement. Quote Link to comment
bananahamuck Posted February 9, 2015 Report Share Posted February 9, 2015 Think this guy ,, lol ,,, has a retro fit replacement dash voltage regulator that fits many different models,, he sells pretty cheap. The way the classifieds are now, i can't find proof but i'm pretty sure i'm correct. http://community.ratsun.net/user/4336-dguy210/ Trust worthy seller Quote Link to comment
datO))) Posted February 9, 2015 Author Report Share Posted February 9, 2015 I'll check it out. For now , I think all the spiders hand crawled out ov my heater core so I'm gonna Hook it all up and try to Get some heat. Quote Link to comment
banzai510(hainz) Posted February 9, 2015 Report Share Posted February 9, 2015 to to the heater core and manually make sure the valve is open. sometimes the cable will not open the valve Quote Link to comment
datO))) Posted February 10, 2015 Author Report Share Posted February 10, 2015 to to the heater core and manually make sure the valve is open. sometimes the cable will not open the valveThere is no heater control valve. I'm thinking it's just a bad pluming Issue or water pump is bad. Quote Link to comment
datO))) Posted February 10, 2015 Author Report Share Posted February 10, 2015 So , what to do with the wagon. The heater issue. After losing sleep over this heater nonsense, iv decided to try a some what unconventional Method. I'm thinking maybe there is a "push" side of the coolant cycle and vacume side. Im taking my lower radiator hose, splicing it with a "T" and running one of the heater hoses to it via the " T" to act as a vacume side . the setup I have now is just pushing the coolant out from each of the motor ports thus no cycle. So in doing this, I'm hoping for a "push" side I.e water pump outlet. And a "vacume " side I.e. Lower Rad. Hose W/ "T" connection. I'll report back With my results and if it's a success, I can Do a step by step instructional . Quote Link to comment
MikeRL411 Posted February 11, 2015 Report Share Posted February 11, 2015 To quote [not early pseudo history] the Japanese desrtoyer Captain's Who ran down JFK's PT04 message to JFK when JFK was first runnihg for President {ot the USA [back then for who those who are confused or on "supplemental medication" ] "Rorts of Ruck on your Errection!" Quote Link to comment
