spottedog Posted November 7, 2014 Report Share Posted November 7, 2014 1980 720 L20B with Hitachi carbWith engine warm and idleing, air filter offEngine idles well except for randomly I can hear the carb make a "gulp" or "slurp" noiseand the the idle speed will drop for a second then return to normal.Looking down the primary venturi I think I can see a small splash of fuel each timeit makes the sound and the idle drops.Float level is correct, fuel pressure is a constant 2.5 psi, stock fuel return line ison engine and working, spark plug color looks good. Quote Link to comment
danfiveten Posted November 7, 2014 Report Share Posted November 7, 2014 check the plunger, your in cali where i had issues with my hitachi on my 72 510 thats all stock. Somewhere where i got fuel on the way home from jccs, it caused my plunger to swell to like 3 times its size to where barley enough fuel would come through, had to use fucking vice grips to get the damn thing out. Dont like the fuel you guys have down there, never had a issue up here, was do to the ethanol. Quote Link to comment
datzenmike Posted November 8, 2014 Report Share Posted November 8, 2014 The accelerator pump isn't in use idling. Quote Link to comment
harlow426@mail.com Posted November 24, 2014 Report Share Posted November 24, 2014 If u end up wanting/needing a working carb I've got one. On an 83 720 z24. If u wanted it I'd ship. Let me know soon. thx Quote Link to comment
Charlie69 Posted November 24, 2014 Report Share Posted November 24, 2014 Not sure if the 83 carb will work on an 80 L20B. Quote Link to comment
