datzenmike Posted September 22, 2008 Report Share Posted September 22, 2008 The HB H-190 were all 4 cylinders. The H-233 were VG motors. Good to know thogh. What about total over all width of the axle assy, same as a 720? Quote Link to comment
datzenmike Posted September 23, 2008 Report Share Posted September 23, 2008 Was to 'the yard' and got some measurements across the rear end widths. This is from the surface the rim sits against from one side to the other. I have no idea what the 620 width is, I running an '82 rear but I think it's slightly wider. Anyone??? 150cm or 59.1" '93 Path VG30, H-233, 4.375 ratio, drum brakes, non-p0si 150cm or 59.1" '91 Path VG30, H-233, 4.625 ratio, disc brakes, non-posi 147.5cm or 58.1" D-21 HB Z24i, H-190-ML, 3.889 ratio, drum brakes. 143cm or 56.35" '85 720 Z24, H-190-ML, 3.70 ratio, drum brakes Quote Link to comment
Llittle_Llama Posted September 23, 2008 Author Report Share Posted September 23, 2008 well i devinately want to run rear disc, not for any reason other for the looks. i dont want to put this much money into the drift truck and then have drums, lol. what would the best rear be to go with for the disc and posi? the ones you listed said NON POSI, so the other 2 did have posi? Quote Link to comment
datzenmike Posted September 23, 2008 Report Share Posted September 23, 2008 It was an option on the VG equipped Path abd D-21 HB. These just didn't have it. I checked last w/end by turning the axles. I'm checking on another forum about axle lengths. Would be nice if the D-21 HB axle with disc were the same length as the stock 620. For posi LSD you would have to swap the whole rear end as the 233mm ring gear would NEVER fit the 190 housing. As you can see the Path/HB rears with the H-233 (lsd) are about 3" overall wider than the 720 rear. How wide is the 620 rear end from outer drum surface to outer drum surface??? Quote Link to comment
nismopu Posted September 23, 2008 Report Share Posted September 23, 2008 Theres one junkyard around here that has at least 5 pathys at one time and almost always there's a posi disc setup under one of them. peace. Quote Link to comment
Llittle_Llama Posted September 23, 2008 Author Report Share Posted September 23, 2008 ok, so if i get one thats too long, a shop can cut and re-splice the axles? about what does this cost? i know these are things i should already know going into this project, but i have ideas to save money down the road. did you hb ever come with rear disc? Quote Link to comment
slodat Posted September 23, 2008 Report Share Posted September 23, 2008 dwnshfter, I have to ask - do you read other the projects on here that are related/relevant to your project? The reason I ask is I know of 3 truck projects(mine, fineline and redeye's 620) here on ratsun that are/will use a H190 rear with LSD and disc brakes. All of these questions have been answered in detail. The swap to the larger 233 is a different story. The short version for the H190 is precision power brute LSD (costs about $400) and Beebani/Fineline trooper rear disc brake brackets. Quote Link to comment
Fineline Posted September 23, 2008 Report Share Posted September 23, 2008 The wms to wms on my 73 H-190 is 55". So 3" diff to the HB H-233b. Not a big deal. The LSD option in the Pathfinders seems pretty common. I have seen a few in my time and I would assume the discs are not interchangeable to the housings meant foe drums. So far so good with my H-190 LSD. I'm starting to get the tune right in mine and the rear end is fine. The fact that these things are so light in the rear keeps the thing from hooking super hard. It sounds like you have plenty of other things to be spending your hard earned $ on right now. Quote Link to comment
Llittle_Llama Posted September 23, 2008 Author Report Share Posted September 23, 2008 well is there an issue of running the stock axle for now? should i just put all my effort into the motor swap for the moment? only reason i was hitting this so hard is that this is the one thing i can do on my own. i can go, by myself to the JY and find and pull the axle, do all the running around getting the axles and everything done, then take it to the shop so we can start the install. thats the only reason i was thinking about this so much.... Quote Link to comment
kaoss Posted September 23, 2008 Report Share Posted September 23, 2008 I'm sure that you want to keep all nissan, but, you should consider looking into a square body style Ranger rear end. A lot of them are the same rear end that ford used in the 5.0 mustangs. They are 56 3/4" outer hub to outer hub. There is another great part about them, one of the axle shafts is around 2" shorter than the other. The pumpkin was off centered from the factory on the Rangers. So all you have to do is get another short axle shaft, and shorten one of the axle housings. Blam!!! You have a shortened rear end. Quote Link to comment
]2eDeYe Posted September 23, 2008 Report Share Posted September 23, 2008 The wms to wms on my 73 H-190 is 55". So 3" diff to the HB H-233b. I've been told that the later 620 H190 are 1.5"s wider than the early 620 H190. I never did verify that with a tape, but Icehouse had to flare his 78, I had to just roll the lips to fit my 77to fit the same wheels and tires. I'm going to continue running that 77 rear (unless I find a free H233 to narrow). Gotta tuck those 18"s :D Quote Link to comment
slodat Posted September 23, 2008 Report Share Posted September 23, 2008 I believe yello620 knows about the wider H190 in the late 620's.. Quote Link to comment
]2eDeYe Posted September 23, 2008 Report Share Posted September 23, 2008 I'm sure he does. I think if I can gather the parts, my narrowish 77 H190 will end up will 4:11's the LSD and an aluminum diff housing. Right now though I'm working on getting the axle housing itself attached to my frame...and making more $ for parts :D Quote Link to comment
1fstdat Posted October 25, 2008 Report Share Posted October 25, 2008 Hey why not a Ford 9", any gears you want... cheap spools... discs. a little welding and it cost me 150.00 for the axles to be resplined. Quote Link to comment
