My 1978 B210GX *Supahachi
  • Replies 78
I pulled the wheels and drums off and didn't find anything out of the ordinary. I can turn the axle and can feel a bit of resistance at one point of the rotation (besides the brakes, both sides) Maybe a stripped gear in the diff. I've never worked on a differential before. There is no plate on the back or point of inspection besides looking through the plug holes. What do?
What makes you think it stripped a gear in the diff? Does it not move forward when you try to drive it?
A bit of whine is very common, it comes from running with the gear oil low sometime in the past. Keep the level topped up and it will last forever. The whine won't go away but it won't get worse.
Got tired of riding around with crappy paint. The fenders were replacements and the red was peeling off. I had to do something to cover up the rust spots. This is the color I want
Also, I used rustoleum double coat and it was the best ever. Took two cans to do the car.
That green may have been my Bs original green. What is the color code?
That blue one looks rough, would make a great rat but I would be scared to see what kind of rust it's hiding. However... I want that passenger fender  :devil:
Here is a shot for color comparison. It's similar:
Blue is nice. Saving up for this one http://charlotte.craigslist.org/cto/4550952438.html
Would be good to store for parts or fix up for my lady (auto transmission)
What part of VA are you in?
I'm actually not in VA anymore, sorry. I need to update that, been gone for over a month now.
I totally would have helped you with that, too man. My bad.
Got the goods!
10487377_538913459570643_134650829700031
Folder full of receipts etc. The PPO bought the car in '93 and in October '94 it was restored. Huge list of goodies. Nissan reman A14 was swapped in at 234k so in total it's at ~340k miles. Oil changes 3-5k miles. The list is pretty long. I'll probably scan it in tomorrow. Hoping to get it back up to par by Oct '14.
Last week, got some parts in from rockauto. Ignition components, shock absorbers, and wiper blades. Got a nice hot spark and a lot less skip.
995029_543906299071359_89692342202382369
Ride is pretty stiff now and have gained a lot of control. No more bouncy house and bottoming out. First time changing shocks before. Don't know how I've managed to miss out in the past. Was a piece of cake!
10524306_543906205738035_310970859213450
Crawled under the front to take a look at the transmission etc. still trying to source the noise. This fucker:
10524564_543906202404702_395427489037733
took a WHILE! Accumulated a pile of tools in the process.
10537446_543906352404687_315941919025974
But of course, when I finally get it out, it's full of good clean dope :)
Fun times..
Hmm something isn't right here...
10532535_543906199071369_347252460993117
Exhaust leak located  :fu:
I'm gonna scrap the cat and go buy some pipe and a glasspack.
Went for a test cruise and saw this beauty downtown. PRISTINE I dare say. The last of a great era.
1231609_543906599071329_7494951762295247
10552554_543906569071332_352017880742022
10561527_543906462404676_690178558792944
10540857_543906429071346_182737221500053
Most definitely under 100k miles.
    Today was the day I pulled the carb to investigate some leaks I was damn sure I would find. No pics, sorry  :yawn:
Was a breeze (besides that rear passenger corner base nut, It shall have it's own meme, and I shall invest in a stubby wrench)
Got all set up on the porch and dug around till I found that NOS carb kit.  . I broke open the carb and found shredded soggy gaskets, leaking pumps, etc. It looked as if a very small crazy person smeared  greasy feces all over the place. Turns out the kit had been opened and was possibly for a different carb or contained parts for multiples models at some point.
 I used what I could till I realized the choke body gasket was not going to work. It was leaking between the float bowl and numero uno. So hell I decided to try again. My small town parts store happened to have a rebuild kit in stock. 25 freakin dollars. Tore it down and put it all back together again. Ended up using some parts from my spare carb. \
Practice makes perfect! Like the time I put my L20b together with the cam 180º out  :rofl: trying to figure out why I had no fuel till I realized I was sucking through the exhaust and blowing out the carb. But hey, it only took an hour and a half to tear it back down and put it back together correctly and drive it home! I have a pretty good understanding of this teeny hitachi son of a bitch now.
 Anyways, it's running like a top. Starts up and idles so smooth and quiet I can't even tell it's running! Still needs a tune up. Pulled and capped some vacuum devices till I can get some hose and another day of datto driven patience. It get's a little weird under power. Might have broken some dirt loose but didn't get it out of there.
Note: Averaging 27 mpg city and that's not putting around.  B)  Fresh tank with the ignition and carb work and hoping for 30+ (but the gravel is oh so fun)
That looks pretty amazing. I'm not a fan of white though due to the fact that it makes imperfections stand out. Black is the same way. However, if you were able to have the body perfect, that would be amazing.
Just wondering, do you plan to keep the park benches? They really don't look bad imo with your current color. I think that is the first B210 I've seen where I wouldn't mind keeping the benches. I think it's the way is it framed in black by the grill and fenders. I think I'm going to try it on my 4dr and see if I like it  :thumbup:
