bk whitest Posted June 5, 2014 Report Share Posted June 5, 2014 i have a 85 datsun 720 regular cab 2wd it is currently riding stock hieght and wondering what can i do to lift the rear maybe a inch or so? truck is used for work but city use as well thanks any adivce is welcome Quote Link to comment
dr.feltersnatch Posted June 5, 2014 Report Share Posted June 5, 2014 1 inch lift blocks Quote Link to comment
datzenmike Posted June 5, 2014 Report Share Posted June 5, 2014 ... and where would you place them? Quote Link to comment
ggzilla Posted June 5, 2014 Report Share Posted June 5, 2014 What are lift blocks? Back in the 80s we used air shocks. Quote Link to comment
Sealik Posted June 5, 2014 Report Share Posted June 5, 2014 Helper springs. http://www.jcwhitney.com/pro-comp-helper-spring/p3066200.jcwx Quote Link to comment
bk whitest Posted June 6, 2014 Author Report Share Posted June 6, 2014 Thanks guys I'll post up pictures Got caught with my 80 720 project and ran into another guy with a 85 720 needing some love Will get pictures up this weekend of both Let you guys know what route he decided to go Quote Link to comment
]2eDeYe Posted June 6, 2014 Report Share Posted June 6, 2014 Longer shackles would be the easiest solution. :) 1 Quote Link to comment
Guest Rick-rat Posted June 6, 2014 Report Share Posted June 6, 2014 Lower the front and the rear will probably look higher B) :devil: 2 Quote Link to comment
bk whitest Posted June 6, 2014 Author Report Share Posted June 6, 2014 i'm interested in the shackles where could i get those at i found the 1inch blocks but as king rat said where would you place them? clearly the rear shocks i would need to replace ? Quote Link to comment
]2eDeYe Posted June 7, 2014 Report Share Posted June 7, 2014 Easy to make, some 1/4" x 1.5" steel strap, drill the holes for the lift you want. Just remember that however much you lengthen the shackle it will be half that distance at the axle. So 1" lift woul mean 2" longer shackle. Quote Link to comment
bk whitest Posted June 7, 2014 Author Report Share Posted June 7, 2014 %5BIMG%5Dhttp://i105.photobucket.com/albums/m206/mohr62720/IMG_2154_zpsbe339b3b.jpg still figuring out the ratsun forums "Global issue" posting up pics lol bare with me while I figure it out if interested what im working on check the link out im always open to advice thanks guys the brown truck is the one getting the lift the green booger one is lowered 3 inch blocks Quote Link to comment
]2eDeYe Posted June 7, 2014 Report Share Posted June 7, 2014 You want to copy the direct link, then click on the little image icon and paste that into that window. :) Quote Link to comment
ggzilla Posted June 7, 2014 Report Share Posted June 7, 2014 The 1" lowering blocks go between spring seat and axle housing. i found the 1inch blocks but as king rat said where would you place them? clearly the rear shocks i would need to replace ? Yes, if the shocks are worn out, replace them. Quote Link to comment
datzenmike Posted June 7, 2014 Report Share Posted June 7, 2014 No placement of blocks is going to raise the ride height. That's why they are called 'lowering' blocks. Do not use longer shackles, they look like hell on a 2wd. A 2" increase on the back of the leaf spring barely gives 1 inch at the axle. Remove the springs and have them re arched. Quote Link to comment
bk whitest Posted June 9, 2014 Author Report Share Posted June 9, 2014 No placement of blocks is going to raise the ride height. That's why they are called 'lowering' blocks. Do not use longer shackles, they look like hell on a 2wd. A 2" increase on the back of the leaf spring barely gives 1 inch at the axle. Remove the springs and have them re arched. Thanks mike that was clear clarification for me over the weekend I was checking it out and was still confused lmao thanks Would you recommend adding those helper leafs ? An inch or two lift nothing too serious Quote Link to comment
]2eDeYe Posted June 9, 2014 Report Share Posted June 9, 2014 http://www.jcwhitney.com/max-air-twin-tube-shock-by-monroe/p3059245.jcwx?filterid=d50465y1977g2j1 These would probably do the trick as well. Quote Link to comment
