Stoffregen Motorsports Posted March 4, 2015 Report Share Posted March 4, 2015 Drop the center link of the tie rod assembly. You don't have to remove it from the steering knuckles, just in the middle. 1 Quote Link to comment
banzai510(hainz) Posted March 4, 2015 Report Share Posted March 4, 2015 hopefully you filled that oil pump with thick oil!!!!!!!!!!!!!!!!!! then stuck it back in timmed Quote Link to comment
Curt Posted March 4, 2015 Author Report Share Posted March 4, 2015 There is oil in the pump. It's 10/30. Quote Link to comment
banzai510(hainz) Posted March 4, 2015 Report Share Posted March 4, 2015 I have done 2 motors and just primed the carb fuel pump(pump by hand before installing) so its squirting gas in the carb. pour oil over cam lobes and down chain. fucking start it. oil pressure in about 15 sec. It will seem a long 15 secs but should be fine. Quote Link to comment
Doctor510 Posted March 4, 2015 Report Share Posted March 4, 2015 Truck, drop the cross member and the idler arm assembly, makes it easy! In a 510, just drop the idler arm assembly. Quote Link to comment
