1975 Datsun 620 Oil Pan Gasket
  • Replies 6
Or instead of a gasket, use Permatex RTV silicone sealer "gasket maker". But be careful not to use too much and to follow the directions (e.g. let it partially set up before assembly).
If you are extremely careful it can work fine. Do not over tighten. The small oil pan bolts need small torque.
