Justin Tawney Posted May 24, 2014 Report Share Posted May 24, 2014 i think i found my problem!! I am super bad with wiring don't know much about it but found out all of the wires to the voltage regulator were cut. I had a wire from the battery to the ballast resistor to the coil to the dizzy and it wasn't getting the right voltage. so I need some pictures of what colored wires go where look at some wiring diagrams but cant understand those. shows the voltaghe regulator hbas 6 wires? mine only has 3.. so any help on this will be very greatful thank you! Quote Link to comment
MikeRL411 Posted May 24, 2014 Report Share Posted May 24, 2014 For what vehicle and year? Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 oh yeah its a 70 521 Quote Link to comment
flatcat19 Posted May 24, 2014 Report Share Posted May 24, 2014 For what vehicle and year? Maybe a '70 521. Did someone put an IR alternator in this thing and rewire the regulator for that? Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 wasn't running when I got it. and whats an IR alternator? Quote Link to comment
DanielC Posted May 24, 2014 Report Share Posted May 24, 2014 IR = Internally Regulated. Look at the connections for the small wires on the alternator. if you see a "S' and a "L", it is an internally regulated alternator. Externally regulated alternators have a "F" and a "N". Quote Link to comment
ggzilla Posted May 24, 2014 Report Share Posted May 24, 2014 Newer alternators use 3 wires. Can you post a pix of the alternator? Stock early 521 alternator has four wires + big A wire. Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 it has F N on it Quote Link to comment
ggzilla Posted May 24, 2014 Report Share Posted May 24, 2014 That should have four wires: A - output Y - Field (F) WB - Neutral (N) B - Earth (ground) The regulator needs six wires. Maybe splice them back together? Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 im tryin g to post some pictures Quote Link to comment
flatcat19 Posted May 24, 2014 Report Share Posted May 24, 2014 im tryin g to post some pictures Load images to photobucket-C/P the IMG code to here. Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 phot bucket wont load Quote Link to comment
ggzilla Posted May 24, 2014 Report Share Posted May 24, 2014 Looks like the stock 1970 alternator. The loose wire, the black one, should be bolted to the E screw on the alternator. Do you have photos of the regulator? Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 the thing hanging there is the voltage regulator correct? Quote Link to comment
ggzilla Posted May 24, 2014 Report Share Posted May 24, 2014 Horn won't work until this is bolted onto the body. Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 that's for the horn? Quote Link to comment
wayno Posted May 24, 2014 Report Share Posted May 24, 2014 The thing hanging is the horn relay. Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 well shit what does the voltage relay look like and where is it? Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 regulator Quote Link to comment
wayno Posted May 24, 2014 Report Share Posted May 24, 2014 It is a larger box in back of where the horn relay is mounted. Basically it is just in back of the rear battery mount support. What area do you live in Vancouver? I live in Cascade park. Quote Link to comment
Justin Tawney Posted May 24, 2014 Author Report Share Posted May 24, 2014 on 4th plain by clark Quote Link to comment
wayno Posted May 24, 2014 Report Share Posted May 24, 2014 OK, we have talked before, I don't have my voltage regulator connected, but it is still in the truck. In the top left corner of the photo below, see the green wires that are looped into the plug, that is the voltage regulator plug bypass for an internally regulated alternator, the external regulator is the box behind the plug. Quote Link to comment
ggzilla Posted May 24, 2014 Report Share Posted May 24, 2014 Man Wayne what happened to your truck does that still run? Quote Link to comment
ggzilla Posted May 24, 2014 Report Share Posted May 24, 2014 VR looks like this Quote Link to comment
