jimmy billy Posted May 21, 2014 Report Share Posted May 21, 2014 Hey a budy of mine may have a z motor outa a 200. I dont know what size yet but i looked up hp spec for a 24 and it sead 103 to 106 depending on year. Is theis a better motor then my L16 same or is making a low budget lz motor better? Ive tryed to search but didnt find the info. And will this bolt z block bolt up to my tranny? Quote Link to comment
flatcat19 Posted May 21, 2014 Report Share Posted May 21, 2014 Low budget LZ. You're funnier than your writing is bad. ^ That's about all I can make out. The other parts you can search for-since you seriously spent ZERO time looking. 2 Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 Out of a 200sx????? They only came with Z20E '80-'81 and Z22E '82-'83. Both are fuel injection and both will not properly bolt up to your L16 transmission. The Z20E is basically an L20B with a different style head on it. If a Z22E, then with some L20B parts you could make it into a 2.2 liter L series motor. Find out what Z series motor it is. Quote Link to comment
MikeRL411 Posted May 21, 2014 Report Share Posted May 21, 2014 Well, he's from British Colombia, so we don't have the Francophile excuse! Quote Link to comment
flatcat19 Posted May 21, 2014 Report Share Posted May 21, 2014 Mike to the rescue. Spoon in hand. 2 Quote Link to comment
jimmy billy Posted May 21, 2014 Author Report Share Posted May 21, 2014 Internet doesnt like me haha i have the hardest time finding things. Thats why i go on forums and ask people that have done this or know about it. I have spent time searching even on this search engine and im not finding the info i want. I did read up a bit about the z motors and they sead their very simlar to the L motors. The head they changed to lower emisions by puting the intake in the other side. I started reading up on a guys build but it was drawn out too much. I was told by a guy on fb to put my head on a z block. Thats why im interested in this. But at the same time i dont understand cause the write up on the motor doesnt sound too impresive. Quote Link to comment
flatcat19 Posted May 21, 2014 Report Share Posted May 21, 2014 I'm guessing you have a 210 head. Right? Quote Link to comment
ggzilla Posted May 21, 2014 Report Share Posted May 21, 2014 This is totally crazy. None of that is right. If you want a bigger engine than a 1.6 liter, swap in a larger engine. There is no need to swap heads or build a hybrid L+Z engine. It is less about the peak HP ratings and more about the fact that ITS A BIGGER ENGINE. Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 Well the L18 and L20B are close to a drop in but it becomes much more complex with anything larger such as a KA because they are EFI and all the issues associated with this swap such as replacing transmission, fuel pump, drive shaft shortening, mounts and cross member, rad. Not something fora beginner. This leaves converting a larger Z series motor into an L series... making it a hybrid. This will fit easier and be larger. Quote Link to comment
jimmy billy Posted May 21, 2014 Author Report Share Posted May 21, 2014 No fatcat i have a L16 out of a 510 and my budy may have a z motor. And ggzilla i know its a bigger motor..... Ya it is alot of work to swap a ka in datzenmike. Dont forget the wiring haha. Its a mess when its in a s13. I just couldnt understand why this guy on the ratsuns fb page would tell me to swap the head... i do like my L its simple and one day i may get a few more ponys out of her but for now i gotta get her running and body work done. When i hear about something i try to look it up as much as i can. When i cant find the info im lookong for i go to people i know should have the awnsers or at least point me in the right direction with out being dicks. Datzenmike and i have had this talk before hes explained the search engine to me and i am geting better with it. Quote Link to comment
laotsu Posted May 21, 2014 Report Share Posted May 21, 2014 what are the numbers stamped on the side of the L head you have? I'm guessing you have a 210 head. Right? Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 The L16/18/L20b/Z20/Z22/Z24 (even the KA) are all the same bolt pattern to the transmission, however they are mounted with different lean or tilt in the engine bay and so the L and Z transmission bolt patterns are 'clocked' differently. L and Z transmissions can't be swapped but the Z engine can be 'converted' into an L series by swapping head, oil pan, mounts and timing gear and then it will mount to an L transmission. This is a very simplified description but easier than swapping to a KA or other large displacement motor. Quote Link to comment
ggzilla Posted May 21, 2014 Report Share Posted May 21, 2014 I just couldnt understand why this guy on the ratsuns fb page would tell me to swap the head...Because: 1. It's fb, not the real Ratsun. On fb generally talk is fast and cheap. 2. By combining the larger engine (Z-series) with the best head (L-series), it makes a superior engine. BUT ... which head is crucial. Most L heads will be wrong for a big displacement engine. A Z22 or Z24 with its own stock head will run well for sure - and likely better than a random combination of L and Z parts. The best L+Z hybrids are a classic hotrod motor build -- bigger engine + carefully chosen components = great engine. Guys tend to forget that and think it is simply a magic combination. Its more than just swapping the cylinder head. Quote Link to comment
jimmy billy Posted May 21, 2014 Author Report Share Posted May 21, 2014 By the sounds of it id rather put the work into swapin a ka instead. But i like my L16 for now. I would like to get a little more hp outa my motor like 110hp or so but like i sead i have alot of work to do. Ill find out the head numbers tho just so i know what i have. Im sure its not a peanut head (i wish!). And datzenmike im giving you the kingrat award for always being helpful when ever ive need help in questions ive asked and always steering me in the right direction. Good job sir :-D Quote Link to comment
jimmy billy Posted May 21, 2014 Author Report Share Posted May 21, 2014 Ok so i found a ID number under the #1 spark plug and it says 29 I found another number in the front of the head at the bottom where it meets the block and it says 219 And the block says L16 226892 Quote Link to comment
laotsu Posted May 21, 2014 Report Share Posted May 21, 2014 the head is a very sought after 219 Peanut head. It's aboot the only thing you can do to increase power on an L16. If you end up engine swapping save/seel that head... or give it to me. Quote Link to comment
laotsu Posted May 21, 2014 Report Share Posted May 21, 2014 here read http://www.datsuns.com/Tech/510/L4_cyl_heads.htm Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 It's slightly lower compression than stock but still worth having. Quote Link to comment
jimmy billy Posted May 21, 2014 Author Report Share Posted May 21, 2014 So your saying ( and that link is saying) is that i have a peanut chamber head...... :-D Ok so with that being sead what would be the best build for me in the future with this head? Stay with the L16 or swap the head on something else and make use of this head? Quote Link to comment
laotsu Posted May 21, 2014 Report Share Posted May 21, 2014 the 219 is only good for the L16. more power is going to come from an engine swap Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 the 219 is only good for the L16. more power is going to come from an engine swap Rubbish! Good on any 4 cylinder L series. On the L16 it does drop the compression slightly unless it also includes the SSS pistons. It (the 219 head) has monster size valves and ports for extreme RPM breathing. On an L18 the compression jumps to 9. On an L20b it jumps to 8.9. The benefits of a closed chamber head are best realized if you also have flattop pistons. Any dish defeats the purpose some. Quote Link to comment
jimmy billy Posted May 21, 2014 Author Report Share Posted May 21, 2014 So it sounds like the L18 block is the better one for me to go with. Now the sss piston's are probobly harder to come buy. I heard of z car pistons working...... Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 Go for size. 2 liter instead of 1.6. L20B will make 15-20 more hp than the L16 (with no changes) and with a 219 head potentially more. Quote Link to comment
Sealik Posted May 22, 2014 Report Share Posted May 22, 2014 Or a Z22...or a Z22 bored to 89mm Just have to modify a HG and drill a few holes in the deck. Quote Link to comment
datzenmike Posted May 22, 2014 Report Share Posted May 22, 2014 Now you're talking. Larger displacement always makes more power with same equipment added. Fits where ever an L16 would fit, although the L16 transmission is becoming a little light for handling this. Simple carburetor engine. Quote Link to comment
