Ottoman0331 Posted March 5, 2014 Report Share Posted March 5, 2014 I just bought a 1977 280z. I removed the center console to attach the new shifter boot to the console. Well under the console I found a old factory looking toggle switch that had 3 positions. The wires were green. One was solid and the other 2 were green with a stripe. While I had it apart interlaced the switch and installed it into the console but can figure out what it goes to. So far it doesn't seem to do anything. Anyone know the switch I'm talking about? Quote Link to comment
datzenmike Posted March 5, 2014 Report Share Posted March 5, 2014 Rear defogger or emergency 4 way flasher. Quote Link to comment
ggzilla Posted March 5, 2014 Report Share Posted March 5, 2014 So the 280Z had a factory installed toggle switch? Other Datsuns last used those in the 1960s Quote Link to comment
datzenmike Posted March 5, 2014 Report Share Posted March 5, 2014 I thought he meant rocker switch. Quote Link to comment
Ranman72 Posted March 5, 2014 Report Share Posted March 5, 2014 I just bought a 1977 280z. I removed the center console to attach the new shifter boot to the console. Well under the console I found a old factory looking toggle switch that had 3 positions. The wires were green. One was solid and the other 2 were green with a stripe. While I had it apart interlaced the switch and installed it into the console but can figure out what it goes to. So far it doesn't seem to do anything. Anyone know the switch I'm talking about? pics would help us help you Quote Link to comment
Ottoman0331 Posted March 5, 2014 Author Report Share Posted March 5, 2014 The rear defogger and hazard switch are accounted for. Will take a pic and try to figure out how to post it tomorrow. Quote Link to comment
ggzilla Posted March 5, 2014 Report Share Posted March 5, 2014 Rocker switch Toggle switch Quote Link to comment
Ottoman0331 Posted March 5, 2014 Author Report Share Posted March 5, 2014 This is a pic of the toggel switch. I made a mistake the wires are blue instead of green. Quote Link to comment
ggzilla Posted March 5, 2014 Report Share Posted March 5, 2014 That is not a factory switch, so its anybody's guess what its for. Quote Link to comment
dr.feltersnatch Posted March 5, 2014 Report Share Posted March 5, 2014 I would guess either fog lights that may have been removed or a hidden kill switch. Doesnt look factory to me. 1 Quote Link to comment
Ranman72 Posted March 6, 2014 Report Share Posted March 6, 2014 agree it is not factory so I have no idea what its for try chasing the wires to where they go or look for cut wires or wires not connected to anything Quote Link to comment
datzenmike Posted March 6, 2014 Report Share Posted March 6, 2014 Remove it and forget it. 1 Quote Link to comment
SS320 Posted March 6, 2014 Report Share Posted March 6, 2014 The hidden two position switch I found in my 320 was a kill switch... 1 Quote Link to comment
captaingamez Posted March 6, 2014 Report Share Posted March 6, 2014 Welcome to datsuns. Quote Link to comment
Ottoman0331 Posted March 12, 2014 Author Report Share Posted March 12, 2014 This is the connector for the wires. The toggle switch may not be factory but the wires are. The connector is located under center console. The connections for the hazards, defrost, seatbelt and fuel light are accounted for. Quote Link to comment
rob123 Posted October 12, 2014 Report Share Posted October 12, 2014 antenna switch Quote Link to comment
Ranman72 Posted October 13, 2014 Report Share Posted October 13, 2014 antenna switch thinking the same thing they have a toggle for the antenna from the factory but that switch is not factory Quote Link to comment
datzenmike Posted October 13, 2014 Report Share Posted October 13, 2014 Usually when you turn the radio on the antenna goes up. Goes down when turned off or ignition off. Quote Link to comment
Ranman72 Posted October 13, 2014 Report Share Posted October 13, 2014 Usually when you turn the radio on the antenna goes up. Goes down when turned off or ignition off. most if not all z,s had a toggle or rocker switch for the antenna early 240,s had a rocker early radio top right is rocker switch for antenna another year factory rocker for antenna 1 Quote Link to comment
