vindats1 Posted September 1, 2008 Report Share Posted September 1, 2008 hey has anyone ever converted a 520 or 521 (mine has the L 16) to an auto? Still having so much knee pain after knee replacement, really want to drive my little truck, got new tires too. Sure would be great to be able to drive it on a daily basis...now it just sits and I hate that. Any advice...guess we need to find out a few things about bolt patterns, etc first. thanks for any help, Tana Quote Link to comment
bonvo Posted September 1, 2008 Report Share Posted September 1, 2008 i dont see why it cant be done there are a bunch of 510 autos out there pull the tranny and go from there (im with you on the knee pain mine is perminantly screwed from an accedent at work) Quote Link to comment
Gensaiken Posted September 1, 2008 Report Share Posted September 1, 2008 I don't see why it couldn't happen. Think you might need to transfer some relays or do a bypass park switch. Just have to measure any auto trans and make sure it is the right length to fit your stock drive line. From what some have told me there are some 510 auto trans the same size as the stock 4speed. I'm sure datzenmike will jump in and fill in any specifics since he appears to be the auto trans expert. :cool: Quote Link to comment
pl521sss Posted September 1, 2008 Report Share Posted September 1, 2008 You also need radiator with the lower tank for tranny fluid for cooling. There should be folks that still have the old auto tranny laying around. I have one but I'm in California I have everything actually We just removed my brothers auto tranny to manual pedals Hydrulic line Shifter w/ linkage torque converter flex plate vacuum line to intake manifold Intake manifold with the vacuum inlet did I miss anything? Quote Link to comment
pl521sss Posted September 1, 2008 Report Share Posted September 1, 2008 Truck 4.37 gears should work well with the 510 auto tranny Always wondered how much quicker it would be if I switced to 4.11 on my 510 better yet 4.37 Taking off from dead stop on auto is very sloowwwwwwww Yup, I have automatic on my sedan so what :D:D Quote Link to comment
datzenmike Posted September 1, 2008 Report Share Posted September 1, 2008 Here is the 3N71B short tail auto that you need, it's from a 72 510 I believe. Any 510 auto will work but I like the Jatco auto from the later 510s. http://i138.photobucket.com/albums/q251/datzenmike/trans3N71BLseriesshort72510.jpg[/img]"] The 521 and early 620s used the same 4spd but they had a flange out put to mount the drive shaft to. The auto won't have this and accepts a splined shaft. The Front drive shaft can be split at the U joint to get rid of the mate to the flange and have spline U joint put on to replace it. This is not a 521 drive shaft but good for explanation. The top shaft coming in from the right has a U-joint with a flange mount just to it's right (with bolts) similar to what you would see on the end of the 521 4spd. What you need is the left hand side of the U-joint below it. The shiny end has the splines inside it that fit into the auto tranny http..://i138.photobucket.com/albums/q251/datzenmike/620stuff003Large-1.jpg[/img]"] Quote Link to comment
pl521sss Posted September 29, 2008 Report Share Posted September 29, 2008 Here's some info that could be helpful. Auto trans from 1972 Datsun 510 floor shift (Jatco). Plates that goes at the end of crankshaft and flex plate. Hydrulic line from auto trans Lines from Radiator lower tank to trans. Vacuum line from intake manifold to kickdown solenoid. Quote Link to comment
