DROMO620 Posted January 20, 2014 Report Share Posted January 20, 2014 Well i'm new around here and been learning my way around the site, and how to get pretty much get in the mix of everything. So where do i start i'm a guy out if Alamogordo New Mexico with a 79 620 KC that has a L20B engine in it that i picked up off my grandfathers land. I pull the engine out along with the transmission and started trying to tear down the engine, So far managed to remove just about everything from the intake exhaust manifolds etc but when i tried to remove the crank pulley bolt I snapped the camshaft dowel... So what i'm asking is there a way to remove the bolt without the camshaft dowel intact??? I appreciate any of the help or advice if given Quote Link to comment
ggzilla Posted January 20, 2014 Report Share Posted January 20, 2014 Yes.block the flywheel from turning. Then you can get the crank pulley bolt or cam pulley bolt loose. If you have removed the timing chain, put it back on. Quote Link to comment
DROMO620 Posted January 21, 2014 Author Report Share Posted January 21, 2014 I kinda screwed myself and took the camshaft timing gear off and bastard is giving me a hard time to put it back on. But i gave it shot to block the flywheel and no luck man, prob have to block it with something better. If not just gonna borrow a compressor and use a air gun. Quote Link to comment
datzenmike Posted January 21, 2014 Report Share Posted January 21, 2014 Do you have a manual? Might be a good ides. I think the chain tensioner just fell out and this is why you can't get the sprocket back on. You're taking it all apart anyway but if it was in the vehicle, you would have given yourself another half days work to fix this. Quote Link to comment
MikeRL411 Posted January 21, 2014 Report Share Posted January 21, 2014 Broken dowels beat broken bowels any day! 1 Quote Link to comment
DROMO620 Posted January 21, 2014 Author Report Share Posted January 21, 2014 Well broke it loose, and its a A/T trans DatzenMike, and dam right on that MikeRL411 lol Quote Link to comment
EricJB Posted January 21, 2014 Report Share Posted January 21, 2014 Next time you can bolt a long bar of steel to the flywheel, where the pp bolts up, or flexplate where the converter bolts on, and use it as a handle. Quote Link to comment
datzenmike Posted January 22, 2014 Report Share Posted January 22, 2014 Well broke it loose, and its a A/T trans DatzenMike, and dam right on that MikeRL411 lol :lol: I meant repair manual. 2 Quote Link to comment
banzai510(hainz) Posted January 22, 2014 Report Share Posted January 22, 2014 1 Quote Link to comment
DROMO620 Posted January 22, 2014 Author Report Share Posted January 22, 2014 Lmao my bad brotha lmao and yea got me a manual Quote Link to comment
