gryffinwings Posted December 29, 2013 Report Share Posted December 29, 2013 Hi, I was wondering what oil weight you guy are using? I'm using 10W30 high mileage, but I'm getting valve train noise, which is why I'm checking clearances. if my clearances are good, should I put in 10w40? Also I noticed when I started doing valve clearancing that there was a pool of oil right under the cam, but it looks like it's been there for a while, should I just remove it and put in replacement oil before I put the valve cover back on? Quote Link to comment
datzenmike Posted December 29, 2013 Report Share Posted December 29, 2013 Newer cars use roller cams and every year oil contain less and less ZDDP in them. ZDDP is an anti scuffing agent that protects our cams but not needed in the new cars and it clogs their catalytic converters and enters the ecology as an emission. 15w40 Shell Rotella T or Chevron's Dello 400 is good. It's a light diesel oil that still contains reasonable levels of ZDDP necessary for use with our flat tappet cams. It's also slightly higher detergent. Just tell the guy at NAPA you have a flat tappet cam (just like a chebby owner) he'll know what you need. There is also a racing oil but can't remember the brand. I don't see the sense of running expensive synthetic oils on our old worn motors. It will simply leak past the old seals. Quote Link to comment
MicroMachinery Posted December 29, 2013 Report Share Posted December 29, 2013 I switched to Delo 400 15w-40 and have been very happy with it. Quote Link to comment
datzenmike Posted December 29, 2013 Report Share Posted December 29, 2013 The oil caught in the cam valley is normal. Not worth the bother to try and remove. Every part inside the engine block will have old oil on it too, plus the oil pump and all the oil galleries and that oil would have had old oil from before that, and so on. Don't worry about it, 4 quarts of new will dilute it. Be sure not to use a Fram filter. Get a Wix or NAPA brand. Wipe a smear of old oil on the rubber seal so it will twist off easier next time and inspect the block for the seal from the old filter. You don't want two rubber seals. 1 Quote Link to comment
gryffinwings Posted December 29, 2013 Author Report Share Posted December 29, 2013 I'm using an OEM filter from the dealer, so no problems there. Usually I buy WIX filters. From what I've been looking up, Chevron Delo 400 15W40 is the better of the 2, I'll be making the switch after I check my clearances tomorrow. Quote Link to comment
gryffinwings Posted December 31, 2013 Author Report Share Posted December 31, 2013 I finally checked my valves and changed my oil. The intake valves were just slightly loose, and the exhaust seemed slightly too tight, valves are no in spec, that helped the noise some, then I changed the oil to Chevron Delo 400 LE 15W40. Man did those two things quiet down the valve train noise, the engine also seems to run much smoother. I think I'll stick with running Chevron Delo 400 LE, it's so friggin cheap, I also here that Delo 400 LE performs on par with synthetics. Quote Link to comment
datzenmike Posted December 31, 2013 Report Share Posted December 31, 2013 Look up ZDDP a zinc anti scuffing additive. Every year less and less is added to the oils we buy because the new engines don't need it but ours still do. Most or many diesel oils are exempt from this (for now) and this is the reason for the use of the Dello400. I have no idea what the LE contains but if for gas engines you can bet it has lowered ZDDP levels.. Quote Link to comment
gryffinwings Posted December 31, 2013 Author Report Share Posted December 31, 2013 Look up ZDDP a zinc anti scuffing additive. Every year less and less is added to the oils we buy because the new engines don't need it but ours still do. Most or many diesel oils are exempt from this (for now) and this is the reason for the use of the Dello400. I have no idea what the LE contains but if for gas engines you can bet it has lowered ZDDP levels.. Yeah I know all about the issues with ZDDP, also to my knowledge the Delo 400 LE is pretty good and has enough ZDDP, check this thread out: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=811427 Quote Link to comment
mrmark Posted December 31, 2013 Report Share Posted December 31, 2013 I'm using Brad Penn 10w40 Quote Link to comment
izzo Posted May 17, 2014 Report Share Posted May 17, 2014 Just came across this thread. Good stuff. 1 gallon of Delo 400 15w40 is under 12 bucks at walmart. neat! To bad we don't have a walmart. Quote Link to comment
