DaveyDaveDaveDave Posted December 13, 2013 Report Share Posted December 13, 2013 So Im throwing a junkyard L20b in my 620. Guys at the yard said it ran "good" and I used to work with a couple of them, so i believe it. With it out I want to do what I can to keep it "good" while I rebuild the original. This is my DD. Its a 78 motor, barnacled with smog equipment, and was backed by an automatic. w58 head. common stuff. Short plans for the JY motor are front and rear seals timing component inspection oil pan gasket thermostat less emissions (different manifolds) tune up stuff VC gasket water pump Am I missing anything? One other question, did they come with timing covers painted to match the block? This one is. Maybe some insight to previous work? Quote Link to comment
Eagle_Adam Posted December 13, 2013 Report Share Posted December 13, 2013 timing covers were always aluminum, if painted a PO did it. Maybe you got lucky with newer timing stuff inside! Quote Link to comment
ggzilla Posted December 13, 2013 Report Share Posted December 13, 2013 If you do all that, you'll probably void the junkyards warranty. So start with a compression test. If it isn't 'excellent', return the motor. Then start the engine while it is sitting on the ground. It can run 30 seconds without water. If it smokes, return it. 2 Quote Link to comment
datzenmike Posted December 13, 2013 Report Share Posted December 13, 2013 Keep the intake and just disconnect the EGR vacuum line from the carb to disable it. (not going to improve anything anyway) The earlier intakes have smaller ports and there is no gain from this. Keep the exhaust manifold you have as it's a round port and an earlier square isn't a good match.... in addition you would also have to change the single down pipe to twin pipe to fit an earlier square port exhaust manifold. This is a huge amount of work to remove the EGR just for looks. Quote Link to comment
DaveyDaveDaveDave Posted December 16, 2013 Author Report Share Posted December 16, 2013 So the engine I pulled came from a truck with AC. Mine never had AC. Whats the difference in water pumps? Quote Link to comment
Eagle_Adam Posted December 16, 2013 Report Share Posted December 16, 2013 the size of the fan clutch an f the fan its self Quote Link to comment
DaveyDaveDaveDave Posted December 16, 2013 Author Report Share Posted December 16, 2013 Soooo.... it doesnt really matter? Cause thats what it sounds like! Quote Link to comment
Eagle_Adam Posted December 16, 2013 Report Share Posted December 16, 2013 nope, the ac WP will swap to any L4 motor - but you need a specific fan for the AC pump Quote Link to comment
cruznude Posted December 16, 2013 Report Share Posted December 16, 2013 You know I was going to do all you were saying also and after pulling motor and trans and re-doing all could be done, I ended just removing the old Hitachi and replacing with a weber and making a block plate for the EGR valve. Then after cleaning with Purple stuff and painting everything and this includes exhaust manifold, heat sheilds, and puttting all new rubber lines and puttting everything new in the engine compartment, it looks outstanding and the most work I did was putting it all back together and re-installing everything. Wish I understood this photobucket thing I'd show you. Quote Link to comment
MikeRL411 Posted December 17, 2013 Report Share Posted December 17, 2013 Wish I understood this photobucket thing I'd show you. It's covered in the "General Discussion" entry at the top of this site, it's the tenth pinned discussion item. Quote Link to comment
DaveyDaveDaveDave Posted December 17, 2013 Author Report Share Posted December 17, 2013 My volvo should be back on the road end of the week, so I'll have time to doll it up the way I want. Might as well do it right, since I dont know howlong itll take me to get the original engine rebuilt. Ive done all the emissions delete stuff before, but I dont want to bother capping all the hard lines for the smog rail, egr and all that. But when the original is rebuilt, I want this as a known good spare. Or an excuse to buy a datto that needs an engine. So... new timing set (the chain was friggin sssttttrreeeeeeeeetched) and seal it up. The smog and egr can be done in two plugs and I can have the cleaner intake I want. I know, Mike. Wasted effort. I'll buy a new weber when the original engine is rebuilt. Until then, I have good stock carbs. We had sub freezing for a week here, this thing fired up and drove on three cylinders without complaining. I dont mind my stock carbs. Quote Link to comment
