Here Is Something Out Of The Ordinary, A15 Inside
toyota1515
This is a amazing Powerplant here from one of my friends in Puerto Rico it is a Daly driver Suzuki LJ20 that uses a non comon A15 Datsun engine, i said non comon cuz in PR that is not the engine of choice whatsoever, and what is very awesome about this is this one is the most competitive Street drag 4x4 on the class in the races in PR. and puts out 424+ WHP out of the little powerplant.
CB756C17-1CF1-44D0-AF73-814E428B198E_zps
https://www.facebook.com/photo.php?v=562018017190253
  • Like 3
  • Replies 20
Oh yes also stainless valves Toyota 3TC valvesprings brass valve guides presicion 6262 billet turbo sparco intercooler ARP studs everywhere and believe it or not stock rocker arm system and a 472 lift mild cam, there is a lot left in it. future plans are a 1.5 ratio Terr Yella T&D rocker arm system setup Smith Bros chorme moly pushrods and a better cam profile, with the more stable vlavetrain system and the better cam profile it should improve a lot in the HP department.
Thing with Yella Terra is that you need to make em work, is not a straight bolt on setup, and as you read here this head is extensivelly modiified with many out of the ordinary parts like toyota valvesprings and stainless valves from othe source with custom bronze valveguides, it got race valvespring keepers that are tall, that makes the valespring keeper to rocker arm clearance easyer to deal with.
Yep.
Uses electric water pump.
Installed in B210
Very cool! Anymore details on the build? Output HP, machining needed, etc.... Looks like they had to do away with the distributor also to clear the intake...
