jrock4224 Posted October 30, 2013 Author Report Share Posted October 30, 2013 when the fork is extended till it touchs the clutch tines ... then theres only 3/8inch or less behind it in the opening for the arm to move ....most all my other cars the arm is in the middle of the opening with about 2-2.5 inches of throw available...moving the throw out closer with a thicker collar will move the arm back into the middle or at least closer....right now there's no way the clutch could operate .... the slave was set up for the l16 same tranny but when we switched the first time ii pushed the clutch it pushed the rod and piston almost out and was bound the fuck up I looked and was like hmmmm that's not right .....so yes the l16 appeared to have the arm set up closer to where im trying to get .....which makes sense...... the pressure plates is the same spec wise as the other plates I have from 225mm l20 clutchs...... Quote Link to comment
bananahamuck Posted October 30, 2013 Report Share Posted October 30, 2013 I'll go out and measure the ones i have lying around,,, but that will mean putting my pants on,, so let me finish my coffee and drool over others hard work for a few,, and i'll let you know.. B) Quote Link to comment
banzai510(hainz) Posted October 30, 2013 Report Share Posted October 30, 2013 rockauto shows a kit with a sleeve Quote Link to comment
bananahamuck Posted October 30, 2013 Report Share Posted October 30, 2013 I got one that measures out to 52 all the way out to the end of bearing ,, i'll bring what i have over in the morning tomorrow.. If you whip yours out we can compare right in the front area. giggity. 2 Quote Link to comment
jrock4224 Posted October 30, 2013 Author Report Share Posted October 30, 2013 im standing here butt naked waiting.......oh u meant the sleeve .. I may have one ... check my thread later tonight o see what I come up with ... Quote Link to comment
