ka24 or sr20 rods?
  • Replies 19
Well some time in the future I wanna rebuild my motor butI know they don't make forged l20b rods but eagle make rods for the ka motor, so if they fit then id like to use them
Did you read that thread I posted? It gives the length of different Datsun/Nissan rods.
Do you need a motor? Where are you located?
Stock L series bottom ends (rods & cranks) are forged. No need for aftermarket.
You can't have been searching too hard.
Google "datsun L20 forged rods" and the 5th result.
http://www.amazon.com/H-Beam-Connecting-Bolts-DATSUN-Engine/dp/B00EUV8MKA
Bullshit. How can those rods cover 3 different sizes?
Same part number listed for all 3.
I'd bet that they are for an L16/L24 length.
 That didn't even occur to me when I skimmed through that. They list the specs:
H-Beam Connecting Rods (4 PCS) + Bolts for DATSUN 510 L Engine Straight-4 L16 L18 L20.Forged Aircraft 4340 Steel, Highest Level of Strength.High Performance, Supports 600 HP.Rod Length: 5.236" (133mm).B/E Bore: 53mm.S/E Bore: 21mm.B/E W: 26.8mm.S/E W: 23.9mm.Rod Bolt: 3/8".
Probably all generic info....no fucking way any L-4 is going to make anywhere near 600HP without turning itself into butter in the process.
I think the stock L20Bs rods and bolts are ok to 7K.  Anyone planning to run constantly over that is a serious racer and custom rods and forged pistons have been added by now.
As to the KA rod in an L20B. The piston pin would be 3/4" higher on the piston. Leaving about 1/3 of an inch above it for the rings, sorry not going to work.
