GREY1979 510 Posted October 24, 2013 Report Share Posted October 24, 2013 Hi my names Dan im very new to the form and was wondering if anyone has put rods from a ka24 or sr20 in a l20b Quote Link to comment
HRH Posted October 24, 2013 Report Share Posted October 24, 2013 Sure, I turned the block upside down minus crank and put the laid the rods in the bottom. They fit. 1 Quote Link to comment
GREY1979 510 Posted October 24, 2013 Author Report Share Posted October 24, 2013 But did you run it Quote Link to comment
flatcat19 Posted October 24, 2013 Report Share Posted October 24, 2013 http://community.ratsun.net/topic/996-jason-grey-info/ Why do you need different rods? Quote Link to comment
GREY1979 510 Posted October 24, 2013 Author Report Share Posted October 24, 2013 Well some time in the future I wanna rebuild my motor butI know they don't make forged l20b rods but eagle make rods for the ka motor, so if they fit then id like to use them Quote Link to comment
flatcat19 Posted October 24, 2013 Report Share Posted October 24, 2013 Well some time in the future I wanna rebuild my motor butI know they don't make forged l20b rods but eagle make rods for the ka motor, so if they fit then id like to use them Did you read that thread I posted? It gives the length of different Datsun/Nissan rods. Do you need a motor? Where are you located? Quote Link to comment
metalmonkey47 Posted October 24, 2013 Report Share Posted October 24, 2013 Well some time in the future I wanna rebuild my motor butI know they don't make forged l20b rods but eagle make rods for the ka motor, so if they fit then id like to use them Stock L series bottom ends (rods & cranks) are forged. No need for aftermarket. 1 Quote Link to comment
flatcat19 Posted October 24, 2013 Report Share Posted October 24, 2013 No. KA rods are way too long. By 20 or so mm. Not sure of SR rods length. Quote Link to comment
DAT510 Posted October 24, 2013 Report Share Posted October 24, 2013 Yeah make sure the rods are the same lengths, and the holes on the piston side are the right diameter for the pins. Unless you want a higher or lower compression engine? is that why youre running forged rods? boost? lol Quote Link to comment
flatcat19 Posted October 24, 2013 Report Share Posted October 24, 2013 Stock L series bottom ends (rods & cranks) are forged. No need for aftermarket. Was just aboot to post that. Quote Link to comment
metalmonkey47 Posted October 24, 2013 Report Share Posted October 24, 2013 You can't have been searching too hard. Google "datsun L20 forged rods" and the 5th result. http://www.amazon.com/H-Beam-Connecting-Bolts-DATSUN-Engine/dp/B00EUV8MKA Quote Link to comment
flatcat19 Posted October 24, 2013 Report Share Posted October 24, 2013 You can't have been searching too hard. Google "datsun L20 forged rods" and the 5th result. http://www.amazon.com/H-Beam-Connecting-Bolts-DATSUN-Engine/dp/B00EUV8MKA Bullshit. How can those rods cover 3 different sizes? Same part number listed for all 3. I'd bet that they are for an L16/L24 length. Quote Link to comment
metalmonkey47 Posted October 24, 2013 Report Share Posted October 24, 2013 Bullshit. How can those rods cover 3 different sizes? Same part number listed for all 3. I'd bet that they are for an L16/L24 length. That didn't even occur to me when I skimmed through that. They list the specs: H-Beam Connecting Rods (4 PCS) + Bolts for DATSUN 510 L Engine Straight-4 L16 L18 L20.Forged Aircraft 4340 Steel, Highest Level of Strength.High Performance, Supports 600 HP.Rod Length: 5.236" (133mm).B/E Bore: 53mm.S/E Bore: 21mm.B/E W: 26.8mm.S/E W: 23.9mm.Rod Bolt: 3/8". Probably all generic info....no fucking way any L-4 is going to make anywhere near 600HP without turning itself into butter in the process. Quote Link to comment
Zeusimo Posted October 24, 2013 Report Share Posted October 24, 2013 Guy In Aus Made A 2.1 With DOHC KA Head 500 HP Quote Link to comment
GREY1979 510 Posted October 24, 2013 Author Report Share Posted October 24, 2013 Wow im a dumbass lol thanks guys for the help Quote Link to comment
GREY1979 510 Posted October 24, 2013 Author Report Share Posted October 24, 2013 And yes i do plan on boosting it, thants why i wanted a strong bottem end Quote Link to comment
datzenmike Posted October 24, 2013 Report Share Posted October 24, 2013 I think the stock L20Bs rods and bolts are ok to 7K. Anyone planning to run constantly over that is a serious racer and custom rods and forged pistons have been added by now. As to the KA rod in an L20B. The piston pin would be 3/4" higher on the piston. Leaving about 1/3 of an inch above it for the rings, sorry not going to work. Quote Link to comment
GREY1979 510 Posted October 25, 2013 Author Report Share Posted October 25, 2013 Ok thanks datzenmike but when you say 7k do you mean 7000rpm? Quote Link to comment
GREY1979 510 Posted October 26, 2013 Author Report Share Posted October 26, 2013 Ok cool cuz i dont think id spin it that hard cuz it will be a daily driver Quote Link to comment
