pl521sss Posted October 10, 2013 Report Share Posted October 10, 2013 Question to our in house 510 experts. There seems to be difference on 1968 Datsun 510 exhaust down pipe manifold and gasket. I ordered 3 different brands (felpro, Victor Reinz and .....) none of them fit correctly. I'm pretty sure it's factory manifold. Anyone here has dealt with this issue or has the correct part number for gasket (down pipe)? Quote Link to comment
Stoffregen Motorsports Posted October 10, 2013 Report Share Posted October 10, 2013 Both Rock Auto and AGC Supply have the same Felpro part number for 68-73. http://www.agcsupply.com/item.wws?sku=25560&itempk=171664&mfr=FELPRO&weight=0.030 http://www.rockauto.com/ I don't think they are different, but it has been a long time since I have seen a stock 68. Quote Link to comment
pl521sss Posted October 10, 2013 Author Report Share Posted October 10, 2013 Both Rock Auto and AGC Supply have the same Felpro part number for 68-73. http://www.agcsupply.com/item.wws?sku=25560&itempk=171664&mfr=FELPRO&weight=0.030 http://www.rockauto.com/ I don't think they are different, but it has been a long time since I have seen a stock 68. It is slightly different. Will post the picture later so everyone can see. Quote Link to comment
DanielC Posted October 10, 2013 Report Share Posted October 10, 2013 I believe your friendly neighborhood Nissan dealer can get them. Quote Link to comment
KlassicMotion Posted October 10, 2013 Report Share Posted October 10, 2013 I've got the Felpro gasket... It was tight going down the threads, but it sits in place just fine. I've bought others from Nissan as well. I think pictures are going to be be key here. Quote Link to comment
pl521sss Posted October 11, 2013 Author Report Share Posted October 11, 2013 Here's how it looks like with Felpro gasket. Doesn't line up correctly. Quote Link to comment
KlassicMotion Posted October 11, 2013 Report Share Posted October 11, 2013 We believe you now! What does the manifold look like? And out of curiousity, what's the diameter of those pipes? How about buying some material, and making your own? http://www.summitracing.com/parts/php-68070/overview/ http://www.summitracing.com/parts/mrg-5961/overview/ I think I'd take that Felpro gasket you have, cut it in half length wise, and slide it back in to shape to fit the flange. Then tape it together and use it for a template on some fresh material... You might have to get a little more creative to get the pipe holes traced right, but the outside shape, and stud holes should be good for the start of the template. Quote Link to comment
pl521sss Posted October 11, 2013 Author Report Share Posted October 11, 2013 We believe you now! What does the manifold look like? And out of curiousity, what's the diameter of those pipes? How about buying some material, and making your own? http://www.summitracing.com/parts/php-68070/overview/ http://www.summitracing.com/parts/mrg-5961/overview/ I think I'd take that Felpro gasket you have, cut it in half length wise, and slide it back in to shape to fit the flange. Then tape it together and use it for a template on some fresh material... You might have to get a little more creative to get the pipe holes traced right, but the outside shape, and stud holes should be good for the start of the template. This is factory manifold There has to be someone here that has correct part number. Felpro and other brands only carries 70-73 gasket, even though it's listed as 68-73 Will try Nissan but they would be scratching their head if I said use Micro fiche to look up the part number. Quote Link to comment
pl521sss Posted October 11, 2013 Author Report Share Posted October 11, 2013 gasket part number I found online carpartsmanual 20711-21001 20691-A0880 If anyone has access to cross reference these to a Felpro Thanks Quote Link to comment
MikeRL411 Posted October 11, 2013 Report Share Posted October 11, 2013 Here's how it looks like with Felpro gasket. Doesn't line up correctly. That looks like the gasket between the exhaust manifold and the "through the fender" extension of the RL411! I cludged mine by cutting and fitting two 510 gaskets. Quote Link to comment
pl521sss Posted October 11, 2013 Author Report Share Posted October 11, 2013 That looks like the gasket between the exhaust manifold and the "through the fender" extension of the RL411! I cludged mine by cutting and fitting two 510 gaskets. Most of the Datsun collector looks similar with those 2 round holes and 3 bolts to secure it. But differs slightly with spacing and size of exhaust passage. Are you using Part number 20711-21001 or 20691-A0880 If so, will order it for RL411 instead Quote Link to comment
KlassicMotion Posted October 11, 2013 Report Share Posted October 11, 2013 This is factory manifold I'm just curious if there are any visual differences from the ones I've seen... Like if there is a way to tell them apart. I'm guessing if that gasket was only used for one year, you will be S.O.L. If it's the same as the RL411 you might get lucky, but it's not like there are a lot of parts for those either.... Keep us posted.. Quote Link to comment
dr.feltersnatch Posted October 17, 2013 Report Share Posted October 17, 2013 The way I would make a template (if you decide to cut your own) is lay a sheet of white paper over the flange and with dirty hands rub over the top of the paper. The lines will shop up pretty well. Then tape that over new gasket material and cut through both paper and gasket with exacto knife. Quote Link to comment
