xyzalvarez Posted August 15, 2008 Report Share Posted August 15, 2008 hey guys.. i did my tiny search and found the sticky about the LSD's. but still have some questions.. whats the difference between LSD and viscous LSD ? i found a seller with one and the gear ratio ( sticker foil ) reads : " viscous LSD 3.54 " it comes from the Subaru SVX 91 :confused: is that a good or bad swap for the 510 ? any feedback about this one... axels wise / hubs / gear ratio ?? thanks.1 JC Quote Link to comment
521Lvr Posted August 15, 2008 Report Share Posted August 15, 2008 VLSD is a fluid type lsd unit. It is ok for street use but is the least desirable for performance driving. They don't fully engage soon enough and wear out quickly under hard driving. Real Drifters hate them. Still better than the 1 wheel wonder. The subbi xt and a couple others had a r180 same as Datto. Not sure about SVX. That's alot bigger car and prolly used a bigger diff?? Not sure tho Quote Link to comment
xyzalvarez Posted August 16, 2008 Author Report Share Posted August 16, 2008 hooo i see! thanks for your answer... i would look for the " regular " lsd then.. this guy is looking around 300 + 80 shipping for it... almost the same for a non viscous lsd. guess i should keep looking for it, if im going to swap, at least install something that be worth the hassle..lol. thanks. Quote Link to comment
]2eDeYe Posted August 19, 2008 Report Share Posted August 19, 2008 What is considered a 'real' LSD? Lysergic Acid Diethylamide? The way I understand it, all LSD (Limited Slip Diferentials) are viscious. They uses clutch packs to transfer power to both wheels. You do need to add a special friction lube to your gear oil. The packs will wear out eventually, but can be re-built for pretty cheap. After that there are Lockers. Which can be automatic (ratcheting mechanism to disengage the system for turning or cornering). Or selectable (Air or electric lockers - use a switch whenever you want it locked) Which leaves a Spool. Always on all the time. Like my Lincoln Locker in my CJ (welded diff). I have a Trac-Loc LSD in the rear of the Jeep, works great when I hit the throttle, not so much off idle, if at all. For a driver I'd go for the LSD. Drifter would be a spool... Someday the Jeep will have selectable front and rear. Quote Link to comment
nismopu Posted August 20, 2008 Report Share Posted August 20, 2008 people who cant drift well nock on viscous units, they work just the same street driving fun. Also, they don't wear out in like 20-30k, which I doubt you will put on your datsun anyway. peace. Quote Link to comment
xyzalvarez Posted August 22, 2008 Author Report Share Posted August 22, 2008 well i just want it to upgrade... im dealing with a custom driveshaft right now and a " free " maintance diff would be great too.. not planning to drift, im just a cruiser guy who punches it here and there..lol Quote Link to comment
xyzalvarez Posted August 27, 2008 Author Report Share Posted August 27, 2008 does somebody have first hand experience installing these units into a dime? specially the r160 coming from a '92 awd turbo parts needed, or hubs / axel to use...? Quote Link to comment
thisismatt Posted August 27, 2008 Report Share Posted August 27, 2008 2eDeYe;74597']What is considered a 'real' LSD? Lysergic Acid Diethylamide? The way I understand it' date=' all LSD (Limited Slip Diferentials) are viscious. They uses clutch packs to transfer power to both wheels. You do need to add a special friction lube to your gear oil. The packs will wear out eventually, but can be re-built for pretty cheap. After that there are Lockers. Which can be automatic (ratcheting mechanism to disengage the system for turning or cornering). Or selectable (Air or electric lockers - use a switch whenever you want it locked) Which leaves a Spool. Always on all the time. Like my Lincoln Locker in my CJ (welded diff). I have a Trac-Loc LSD in the rear of the Jeep, works great when I hit the throttle, not so much off idle, if at all. For a driver I'd go for the LSD. Drifter would be a spool... Someday the Jeep will have selectable front and rear.[/quote'] Viscous LSD's do not have clutch packs at all, they rely 100% on viscous fluid coupling. That is, they don't have frictional metal to metal clutching, they have discs that rotate close to each other but rely 100% on the viscous fluid to do the coupling after enough sheer force is built up within the fluid, they don't press against each other. Here's an example of the coupling: Quote Link to comment
thisismatt Posted August 27, 2008 Report Share Posted August 27, 2008 does somebody have first hand experience installing these units into a dime?specially the r160 coming from a '92 awd turbo parts needed, or hubs / axel to use...? As far as I can remember, all the viscous units have input shafts of different lengths side to side, so you can't just use stock 510 stubs and have them work. Read this if you haven't: http://kmhafer.datsun510.com/Subaru.htm#Where%20does%20Subaru%20Fit%20in? Quote Link to comment
]2eDeYe Posted August 27, 2008 Report Share Posted August 27, 2008 Interesting. More of a hydraulic effect, but not really... Thanks for clearing that up for me :D Quote Link to comment
xyzalvarez Posted September 3, 2008 Author Report Share Posted September 3, 2008 As far as I can remember, all the viscous units have input shafts of different lengths side to side, so you can't just use stock 510 stubs and have them work. Read this if you haven't: http://kmhafer.datsun510.com/Subaru.htm#Where%20does%20Subaru%20Fit%20in? yeah man...i been reading that link , over and over..lol...i even found it on WRX and subarus forums...thats a popular info link... thanks for the pic too.. im contemplating going vLSD, for the only reason,,, you can get them easier than the clutch one... last weekend, went from junkyard to junkyard...even some subarus shops..and nothing..only Vlsd.. now from the pic you showed me, need to remove the C clips from the shafts..in order to take them out...whats the reason of the datsun clips not getting in? number of teeth? or lenght? Does somebody tried or done it before? Quote Link to comment
compression Posted September 23, 2008 Report Share Posted September 23, 2008 The datsun half shafts rely on the differential to have a male splined stub shaft sticking out. That way you can bolt on your 510 female spline-to-4-bolt flanges adapter things. These are the pieces that your half shaft bolts too. The early subaru clutch-pack R160 diff's had these male splined stubs and your 510 pieces just slide right on and a bolt holds them there. the later subaru diff's (the viscous ones) all have internal (female) splines. So you have to have a splined shaft that goes into them. Hence, they are not compatible with 510 half shafts. Quote Link to comment
thisismatt Posted September 23, 2008 Report Share Posted September 23, 2008 The datsun half shafts rely on the differential to have a male splined stub shaft sticking out. That way you can bolt on your 510 female spline-to-4-bolt flanges adapter things. These are the pieces that your half shaft bolts too. The early subaru clutch-pack R160 diff's had these male splined stubs and your 510 pieces just slide right on and a bolt holds them there. the later subaru diff's (the viscous ones) all have internal (female) splines. So you have to have a splined shaft that goes into them. Hence, they are not compatible with 510 half shafts. What? Early subarus have a splined stub shaft like this which are held in with a bolt down the centers, which is removed and the stubs are pulled out. Here is the splined stub removed and next to the stock 510 stub flange that you replace it with: Quote Link to comment
