ricandatsun Posted July 22, 2013 Report Share Posted July 22, 2013 Hi all, I'm Denny from NC and I owned a 78 Datsun 620. Love my truck, looks similar to my first car back in 93 (77 Datsun 710). Still stuck with a Weber 32/36 carb that is acting up (high idle and too rich). I might go back to original carb from national carburators. What you guys think I should do...? Quote Link to comment
420n620 Posted July 22, 2013 Report Share Posted July 22, 2013 What you guys think I should do...? I would suggest pic's of your 620. just my 2 cents. Oh and Welcome to the form. :thumbup: 1 Quote Link to comment
datzenmike Posted July 22, 2013 Report Share Posted July 22, 2013 Webers are very simple carbs to rebuild. That said many are swapped off old Vegas and Pintos and are ages old and worn out. You will have to decide if woorth rebuilding it. Usually the throttle shaft is too worn. A replacement Hitachi won't be cheap. A new weber is just under $300 delivered. Quote Link to comment
ricandatsun Posted July 22, 2013 Author Report Share Posted July 22, 2013 I'm trying to post some pics but having trouble. I would like to rebuild the weber but I'm afraid is gonna go back to high idle. Filled tank Friday night and by Saturday afternoon it was empty (truck didn't move, parked in front of my garage trying to fix the idle and the richness). Made some calls and I can get a OEM carb from national carburators down in Jacksonville, Fl for $280. 1 Quote Link to comment
Dawa Posted July 22, 2013 Report Share Posted July 22, 2013 id say that if you have the money, its so much more worth it to just start with a fresh new carb. thats what i did. Quote Link to comment
ricandatsun Posted July 22, 2013 Author Report Share Posted July 22, 2013 @Dawa: what kind of new carb did you buy? I've been researching and they have Tomco and the dat612. Quote Link to comment
PDX Matt Posted July 22, 2013 Report Share Posted July 22, 2013 Go with a new Weber if you can find one at a decent price. Quote Link to comment
420n620 Posted July 22, 2013 Report Share Posted July 22, 2013 if you filled the tank and it was empty the next morning, it doesn't sound like the carb unless the float stuck open and drained the fuel into the engine. Did you check the dip stick to see if that's where the gas went ? if the fuel didn't go into the oil pan then it must of drained on the ground or someone had siphoning your fuel. Maybe you got a hole in a hose. :confused: to post pic's you will need to have a picture host like photo bucket, Flicker or W/E. Then down load pic's to pic' host, copy IMG code, paste IMG code to "reply to topic box" and hit post, Whammm, ur done 1 Quote Link to comment
ricandatsun Posted July 22, 2013 Author Report Share Posted July 22, 2013 I was playing with the float back and forward, started truck more than a few times adjusting everything with no luck, I think the foat is bad or stuck. Carb is off truck as we speak Quote Link to comment
]2eDeYe Posted July 22, 2013 Report Share Posted July 22, 2013 mechanical or electric fuel pump? Are you getting gas out of it? You could have a bad rubber line somewhere dumping fuel. Had that happen before. Would get fuel to the carb, but not as much as it needed to run correctly. Most generic electric pumps only pump 3-4 gallons per hour, that's a lot of float fiddling :) Quote Link to comment
ricandatsun Posted July 22, 2013 Author Report Share Posted July 22, 2013 Electric and I have a fuel pressure regulator (set @ 2 - anything lower than that it would idle too dang high like is gonna blow) between filter and carb. Check rubber and checked for leakage, I don't see anything. Quote Link to comment
420n620 Posted July 22, 2013 Report Share Posted July 22, 2013 scratching head. :confused: I think you gotz a thief then. OR someones gone for a joy ride. :huh: 1 Quote Link to comment
ricandatsun Posted July 23, 2013 Author Report Share Posted July 23, 2013 Maybe, dang thieves lol. Can't figured it out. I just need another carb just to swap and double check. Finished installing fender mirrors, lowered 3" in the rear and need to go lower in the front. Need to learn how to upload pics here for you guys to see 1 Quote Link to comment
ricandatsun Posted July 23, 2013 Author Report Share Posted July 23, 2013 Webers are very simple carbs to rebuild. That said many are swapped off old Vegas and Pintos and are ages old and worn out. You will have to decide if woorth rebuilding it. Usually the throttle shaft is too worn. A replacement Hitachi won't be cheap. A new weber is just under $300 delivered. Quote Link to comment
datzenmike Posted July 23, 2013 Report Share Posted July 23, 2013 Gas won't flow up hill into the carb overnight. 6-8 gallons would be all over the place, you'd know. For the price of a couple of gallons get a locking gas cap. Bet your mileage increases. 1 Quote Link to comment
ricandatsun Posted July 23, 2013 Author Report Share Posted July 23, 2013 Hey Mike have you heard bout tomco carbs? O'railly sells them for around $400 How bout the OEM replacement dat612? they go for around $280. I'm tempted to buy another weber, but with recent experience don't know. I don't like the fact of the electronic choke, think manual is ever. Maybe unplug mine and do the "pumping the gas pedal" a couple of time method. Quote Link to comment
PDX Matt Posted July 23, 2013 Report Share Posted July 23, 2013 I'm trying to post some pics but having trouble. I would like to rebuild the weber but I'm afraid is gonna go back to high idle. Why would you go back to a high idle? That can be adjusted. 1 Quote Link to comment
datzenmike Posted July 23, 2013 Report Share Posted July 23, 2013 Webers are fine. Any carb that is old and worn out is junk. As stated yours may have been a factory Vega or Pinto weber carb, rebuilt 6 times and pieces missing. Why would you go back to a high idle? That can be adjusted. This could be a worn throttle shaft. They become oval shape and the throttle plate jams against the casting wall and doesn't close. If you give it a quick tap on the pedal and it drops to idle then this is likely the problem. Quote Link to comment
Dawa Posted July 23, 2013 Report Share Posted July 23, 2013 webers are what everyone are running. i bought a new weber 32/36 dgev (e is for electric choke.) and a locking gas cap is good but theres also that drain plug on the bottom of the tank. never heard of tomco but id say stick with webers is we all speak fluent weber here :) Quote Link to comment
ricandatsun Posted July 23, 2013 Author Report Share Posted July 23, 2013 That's what I've been doing for the past two week, adjusting that weber. The mixture screw don't do anything, float sucks and when in the correct measurement it makes the primary and secondary jets work in the opposite. Don't get me wrong, never had a problem with a weber before. I think the po mess with it and damaged a few things. I just don't wanna put too much and make the engine work harder Quote Link to comment
PDX Matt Posted July 23, 2013 Report Share Posted July 23, 2013 Just rebuild the Weber. Quote Link to comment
ricandatsun Posted July 23, 2013 Author Report Share Posted July 23, 2013 I think I figure out the pics... When I bought it Working little things here and there After a homemade paint job And with new wheels... Thanks to 420n620 for the "Barney style" instructions on "how to post pics" 2 Quote Link to comment
Dawa Posted July 23, 2013 Report Share Posted July 23, 2013 i love long beds. howd you paint the truck? aerosal, paint gun, or roller/brush? good looking paint job although i like that original blue, too. 3 Quote Link to comment
datzenmike Posted July 23, 2013 Report Share Posted July 23, 2013 That's what I've been doing for the past two week, adjusting that weber. The mixture screw don't do anything, float sucks and when in the correct measurement it makes the primary and secondary jets work in the opposite. Don't get me wrong, never had a problem with a weber before. I think the po mess with it and damaged a few things. I just don't wanna put too much and make the engine work harder . Don't understand this. Post a picture of it. Some webers pull open from the other direction? Quote Link to comment
