New Floor Help
raggmann
Hey all, need some advise & pics.
My floors are screwed (aren't they all). I need help build new ones.
I need to do inner rockers as well.
I'm open to pulling the cab if need be but I need pictures of what you've done.
I can take some shots of mine tonight to show what I'm working with if need be.
I was thinking body drop at the same time but am on the fence as I need to have an operating heater here up north.
  • Replies 6
Do you have a MIG welder?
Does the whole interior floor board need replaced, or just sections?
I myself have not done a body drop yet, but there are a few on here that documented doing it, so if you read their threads, most questions will be answered about that.
I have seen a heater box mounted/piped behind the bench seat in an NL320, obviously it doesn't work as a defroster back there, but it likely did put out heat.
Here is a link to one huge body drop.
http://community.ratsun.net/topic/36519-my-521-down-in-the-lab/
This is a thread I have going on with 521 floor repair.
http://community.ratsun.net/topic/51593-floor-repair/?hl=%2Bfloor+%2Brepair
I am pretty sure the cab will have to be removed to completely weld in the new panel, and seam seal it.
See also this thread,
http://community.ratsun.net/topic/49012-521-replacement-panels/page-2?hl=%2Bfloor+%2Brepair&do=findComment&comment=912697
And the project thread that got me started in floor repair,
http://community.ratsun.net/topic/30606-my-ratsun-datsun-521/?hl=%2Bfloor+%2Brepair&do=findComment&comment=458287
I shot a couple pics tonight.
I have been looking at blackdeth666's build for the last year or so and every time I get a raging hardon. And that's just from the BEFORE pictures.
Daniel C, I've been following yours as well as the other 2 you posted. My biggest issue is it needs inner rockers as well as outers. I just don't know if I sould try to replace the inners or just overlap to come of the existing inner that's there.
Wayno, yes I have a mig and other equipment as well. Sure, I'm not as outfitted as some but probably more so than a lot of others.
Here's the drivers front cab mount I built assuming that's all I had to do only to find the inner rockers worse than I'd first thought.
6A23F63D-CEC0-48A5-9B1B-991C6B6E1002-250
This is lookin in the pass window
BF55B6F3-3EE7-4386-9BB5-312A7DA9BF5B-250
Driver door view
1E0BB1A3-A2B9-4376-BAEE-3AB992EB9E7C-250
As you can see, I've cut out the outer and inner (somewhat) rockers
316E177F-1F6F-488B-A141-0E4D010F100F-250
Keep the feed back comin' boys
I'm not scared of burning wire, just glad I do this for relaxation and not a FT job. Lol
As far as the rust-this is the rust freeist thing I think I've ever worked on.
I think I'm just gonna fix what I got, no body drop, and run the late 80's early 90's static drop I'm used to building from back in the day. Hell, I'm soo old I remember when 16's were a "big" wheel.
It's going to be my shop truck for my home shop "NEIDABIGGER Garage" in Botha, Ab
