SR20 S14 Fuel Rail Inlet Barb
I've looked and can't find anything on this.
I have an S14 SR20 and I am trying to transition from the inlet barb on the fuel rail to SS Earls braided hose. It seems that a house clamp does not clamp hard enough. I can still twist the line when fully tightened.
Is there a fitting that mates these two together?
What are my other options that will allow me to use the SS braided fuel hose?
Could I cut off the barb and flare it on the end and use a -6 AN Tube Nut?
  • Replies 36
http://www.oreillyauto.com/site/c/detail/MHC0/MP131516F/N0189.oap?ck=Search_hose+clamp_-1_3485&keyword=hose+clamp
Try these used them to fix a fuel line on a neon worked great. Rated for fuelinjection
Broke 2 of those. They are like BMW clamps.
The SS Braided Hose just doesn't want to compress....
Here is the stock s14 fuel rail inlet barb. I still have to measure the diameter but I think it is 3/8".
I will have to cut the barb off and do a compression fitting or flare it.
I can also cut the whole inlet off all the way to the end of the fuel rail and have a -6 male bung welded onto the end of it...
I use these whenever I can. They are a push-lock to -6 AN adapter.
The Russell Performance part numbers are 640863 and 640853 for 3/8 and 5/16 respectively. They slip over the hard line and snap in place.
Yes, I measured my lines and they are 5/16".
And CRAP. I just ordered some Earls Compression fittings. They are good up to 50 psi. Which I don't think is a huge problem
but I don't like using stuff to the edge of it's performance.
How much do these Quick Connect fittings handle?
And Pics are worth 1000 words! Thanks!
You will exceed 50 psi.  Fuel pressure starts at like 43psi and should raise 1psi per pound of boost I believe.
I tried looking but it does not say what these Push On fittings will handle...
You think the Earls Compression Fittings, although they say 50psi Max, are rated low for liability reasons?
Can I use the compression fittings on my tank? I have a Walbro 255 feeder and a Bosch 044 to the fuel rail.
I would bet the push-lock is rated to 300psi, like most other fittings.
I'm not a huge fan of compression fittings on a fuel system. Usually if you look hard enough, there is a fitting for whatever you're trying to accomplish.
For specialty fittings, I look here https://www.pegasusautoracing.com/advcat.asp?CategoryID=PLUMBING
Sounds like what I need then. So I went and ordered 3 of them. Dang, at $15 a pop, I am glad I only need 3.  :o
Anyone wanna buy some 5/16" -6AN compression fittings? Hahaha  :P
I'll just send them back and eat the $9 handling fee...
Thanks guys for everything.
So all I have to do is cut off the barbed hump and push these on huh?
