msdm Posted December 12, 2014 Author Report Share Posted December 12, 2014 Little bit more progress. radiator installed, clutch master, hec715 coil and electronic dizzy :) 1 Quote Link to comment
Charlie69 Posted December 12, 2014 Report Share Posted December 12, 2014 That L20B is stuffed in there! LOL. Will the hood close. Quote Link to comment
wayno Posted December 13, 2014 Report Share Posted December 13, 2014 My question is where are you going to put the alternator, do you have room under the dizzy? 1 Quote Link to comment
msdm Posted December 13, 2014 Author Report Share Posted December 13, 2014 Alternator is in there and yep the bonnet closes. 3 Quote Link to comment
wayno Posted December 13, 2014 Report Share Posted December 13, 2014 We are used to seeing the alternator on the right side, so having it on the left must b an Aussie thing because of the steering box. There is a lot more room on your passinger side without the steering column over there. 1 Quote Link to comment
msdm Posted December 13, 2014 Author Report Share Posted December 13, 2014 fair enough learn something new everyday. ive been surprised with how easilly everything has fitted in there. quite a few little mods here and there but its in. :) 1 Quote Link to comment
wayno Posted December 13, 2014 Report Share Posted December 13, 2014 What did you do about your heater core outlets, did you remove the heater for now? That's a nice looking motor mount you made, simple. the best way. It looks like you are using a remote power brake booster, does it work on both the front and back circuits, or just one circuit? What is the part number for that remote booster? 1 Quote Link to comment
msdm Posted December 13, 2014 Author Report Share Posted December 13, 2014 no heater at the moment will get to that later. i had the mounds made for me. bit beyond my powers haha. and the booser is a vh44. there is a willwood brake valve in there aswell will have control over front and rear :) 1 Quote Link to comment
msdm Posted January 16, 2015 Author Report Share Posted January 16, 2015 DatRat slowly coming together :) 1 Quote Link to comment
wayno Posted January 16, 2015 Report Share Posted January 16, 2015 It's looking good, body work is next? :) 1 Quote Link to comment
msdm Posted January 16, 2015 Author Report Share Posted January 16, 2015 a little bit of body work. not too much. im trying to save to get my 180b sss into the body shop. im happy to have the ute a rat job :) 1 Quote Link to comment
wayno Posted January 16, 2015 Report Share Posted January 16, 2015 I was just thinking that it would be nice to have the fenders fixed around where the fender mirrors attach, as it is right in your face there, the rest don't look that bad. It's good that it is RHD, the SUs would be a problem if it was LHD. :) 1 Quote Link to comment
msdm Posted January 16, 2015 Author Report Share Posted January 16, 2015 yea the guards will get some love. i have another set that i may get fixed properly down the track. im just keen to get it back together and running for now :) 1 Quote Link to comment
SS320 Posted January 18, 2015 Report Share Posted January 18, 2015 G'day mate. Great to see another '64 downunder. Looking good so far. Keep up the good work. 2 Quote Link to comment
msdm Posted May 3, 2015 Author Report Share Posted May 3, 2015 not much progress with the old girl latley. been saving up some dollars to get the rear brakes, handbrake cable and fuel tank installed then an exhaust and it should be ready to fire up. :) 1 Quote Link to comment
msdm Posted December 14, 2015 Author Report Share Posted December 14, 2015 https://www.facebook.com/media/set/?set=a.539581659400986.141177.363783110314176&type=3 bit more work done recently. fuel cell installed, exhaust modded to fit properly, side rods bigger drag link to fit new tie rods, alternator bracket and adjuster, few other bits. pics added to facebook link above. 2 Quote Link to comment
msdm Posted December 28, 2015 Author Report Share Posted December 28, 2015 wired up enough to get started today yaay :thumbup: runs like shit haha bit of tuning to do maybe switch from the su's to a 32/36 1 Quote Link to comment
wayno Posted December 30, 2015 Report Share Posted December 30, 2015 Did you put PS fluid in the tops? You can also use automatic trans. fluid. While it is running, look down the throats of both of them, are the pistons lifting the same height, if not adjust them to where they both look the same. Also make sure you have no vacuum leaks. These are the screws you adjust the air flow with, it's best if you have a flow meter, but you can get them close enough by eye to sort things out, they both need to look the same at an idle. See the piston in the throat, they both need to look the same while idling, this is mine shut off, it will be just slightly higher when idling. These are the fuel mixture screws on the bottom, I would just turn them both out two and a half to three turns to start, the small upper screw is the idle screw once everything it set properly, at least it is on my SUs. Don't give up on your SUs, they are way better than a Weber if adjusted properly, I can describe how to adjust them in detail, but it would be better done via email in real time, I tell you how to do something, and you do it and tell me what happened, if we set up a time I could be in front of the keyboard, email me, the address is below. wired up enough to get started today yaay :thumbup: runs like shit haha bit of tuning to do maybe switch from the su's to a 32/36 3 Quote Link to comment
msdm Posted January 1, 2016 Author Report Share Posted January 1, 2016 thanks for the info wayno shal give it a go. i do want to keep the su's was only going to change to a 32/36 to see if the motor was any good. i know its leaking from a welsch plug. not sure about anything else yet tho. its all just a test fit and everything will come back out for a clean up now i know it works. 2 Quote Link to comment
