monkbonk Posted April 12, 2013 Report Posted April 12, 2013 Here's my 1984 Mazda b2000. Bought it for $700 back in August or so. You can definitely tell that I'm in sore need of a lower valence in that pic. Crooked front bumper: Had to pull the engine and tear it apart due to a burnt exhaust valve. Installed a new camshaft (stock) and painted it orange. Gonna paint my air cleaner next. It's got the Mazda 2.0 MA engine that is notorious for blowing head gaskets. It's lasted this long without blowing one, to my knowledge. Part of routine maintenance is torqueing the head bolts every oil change. So, I'll keep an eye on it. 17 Quote
Radiant-Designer Posted April 12, 2013 Report Posted April 12, 2013 nice, my landlord has 2 old mazdas in his garage, one with a chevy small block, the other stock. and about 5 parts trucks. If you need any parts let me know (PM me) I am sure he has them . Quote
Rocket Dog Posted April 12, 2013 Report Posted April 12, 2013 My first new car, was an 84 Mazda B2000. I loved that truck. Quote
monkbonk Posted July 14, 2013 Author Report Posted July 14, 2013 I am going to murder this truck. It's plagued with stupid electrical issues. I've got a mini fuse block on the way. Going to get rid of the glass fuse box that's given me nothing but trouble. Main issue now is that the truck just doesn't seem to be getting enough amperage to the starter. I've got good grounds to the chassis and engine block (going to try moving the bitches around again, I guess). Timing is freaking perfect or at least good. It's timed at TDC. Valve lash was set twice. No improvement on starting. Timing chain was done per the Haynes manual on it. Can't be the problem. Starter isn't bad, cranks over with all spark plugs out. Easy peasy. I have to either A) jumpstart it. B) Put in a freshly charged battery. (tried multiple batteries, and they work fine in other cars). I turn the key and it hangs or it'll turn it over slowly, then hang. Installed a battery killswitch as a means of saving the battery (thought there could be a battery draw when sitting). Doesn't do shit for it. When I have the fresh battery in it, it starts and runs fine. Might've fixed the above issue. Tentative. New issue: backfire through carb when engine is shut off/hot. Quote
dato Posted July 16, 2013 Report Posted July 16, 2013 Have you had the starter bench tested?i had the same problem in my 85 mazda 626 the ''new'' starter was defective and would crank the engine over really slow,when it got hot it wouldn't even work... Quote
monkbonk Posted July 16, 2013 Author Report Posted July 16, 2013 Copied from my post on fordcouriercollector: The starting issue was my fault entirely. I used a lot of 4 gauge wiring to run my battery cut off switch under the dash. Reused the old positive battery lead also.I guess the length of the wire added too much resistance in the circuit and didn't allow enough amperage to the starter. The alternator was also only charging the battery at around 13.4 volts or so with this setup.Now it's above 14 volts. My truck is dieseling after I shut it off. Then smoke comes out of the carb. I've got to do some checking there (idle speed, mixture setting and float level). Quote
jrock4224 Posted July 16, 2013 Report Posted July 16, 2013 i had a courier at one point it was a 81... i also had abad ass 1984 mazda sundowner.......also sharing styling cues with the courier Quote
monkbonk Posted July 16, 2013 Author Report Posted July 16, 2013 I need to paint the bed in this one. I'm trying to decide between a light blue (kinda similar to my bench seat) or just black like the rest of the truck. I messed around with the idle speed and mixture screws on the carb. Now I need to drive it and see if it diesels again. Quote
monkbonk Posted December 3, 2013 Author Report Posted December 3, 2013 So, I sold this to some fellard friend back in August (or idk when) for $900. It's sitting in his yard with an empty clutch master cyl and glue stains (from when he super glued a side view mirror on). He'll sell it back to me for $650. I'm torn. I want it, but at the same time.... I don't. I know that they haven't done any sort of maintenance on it, save for a quart of oil every month (has bad valve stem seals or something). It's a bit dirtier than when I left it. I think I will stew on it for a bit? Quote
Kirden Posted December 3, 2013 Report Posted December 3, 2013 For the price I'd grab it back. it has gremlins but you know that going in. If nothing else it's always good to have a beater around and the old mazdas are fun. My first attempt at mini truckin was an 89 B2200 with a harsh static drop. Loved every minute of it :) Quote
monkbonk Posted December 4, 2013 Author Report Posted December 4, 2013 I might buy it back. I don't think it's going anywhere, so I have time on my side. Quote
Mikeystoy Posted December 12, 2013 Report Posted December 12, 2013 funny; mine's an '81 Courier masquerading as an '82 B2000 sport! Quote
LordGray85 Posted June 15, 2015 Report Posted June 15, 2015 I know this is an old post but I just got myself an 81 B2000 and im looking for info on it. I need to know the location of the fuse panel(not the one under the hood)but the one for the interior lights,radio and so on. Ive googled till i cant google any more! Quote
monkbonk Posted June 15, 2015 Author Report Posted June 15, 2015 I don't know of any other fuse panel. The one under the hood can be really finicky as it is exposed to the elements. Try asking on fordcouriercollector. It is a slow forum though, so expect to wait three weeks for an answer. Quote
pishta Posted December 30, 2024 Report Posted December 30, 2024 There are no fuse panels under the dash. They are all under the hood in the 8 glass fuses. Notorious for rusting underneath and corroding the 2 buss bars. Im looking for a complete 1.8-2.0 engine in So.Cal if anyone has one. Quote
Guest Posted January 13, 2025 Report Posted January 13, 2025 Damn. I need to look out of State for a truck like that. I've been keeping my eye out for a decent little very used small truck, and I ran across a '74 620 ad today where the guy is asking $3500 and the truck is mostly disassembled, and the interior looks like coyotes took up residence in it.. We have harsh smog laws and penalties, and a '75 or earlier vehicle fetches more money out here. Quote
EDM620 Posted January 13, 2025 Report Posted January 13, 2025 I know where there's a Chevy Luv with a California Stepside box on it... Quote
datzenmike Posted January 13, 2025 Report Posted January 13, 2025 The dollar doesn't buy as much as it did when Ratsun started. What you could buy for $100 in 2005 now costs $161 in 2024 https://www.bankofcanada.ca/rates/related/inflation-calculator/https://www.minneapolisfed.org/about-us/monetary-policy/inflation-calculator Quote
tonalteco Posted June 7, 2025 Report Posted June 7, 2025 I dont know how old this topic is but i have an 84 b2000 sundowner and the issue this one gives me now is that all the sudden the fuel pump and instrument cluster died... all the fuses are fine .. now that i replaced the pump it runs but no blinker lights or instruments not at all... just headlights... Any ideas? Quote
ggzilla Posted June 7, 2025 Report Posted June 7, 2025 Fuse box being in the engine compartment is notorious for getting slight corrosion, and even when a fuse is good, not working. So try taking the fuse out, and put it in again It looks like a Ford Courier Quote
datzenmike Posted June 7, 2025 Report Posted June 7, 2025 Test those fuses that have power with ignition on. If none, go to the fusible links they will be mounted very close to the positive battery terminal cable. Check connections. They are as the name implies a fuse also and protect the cables between battery and ignition and the fuse box. Quote
tonalteco Posted June 10, 2025 Report Posted June 10, 2025 Thanks for the guidance.. i will be checking for thet.. also someone said that the cluster plug may be loose... Quote
