edekalil Posted April 5, 2013 Report Share Posted April 5, 2013 Been a while sence I have researched what would and would not work on a 510. I have to locate and read a lot of the materalI have but I'm wondering if the 240z struts would work on a 510 or are they to long ( have to be cut and rewelded) I do know 280zx struts will work. I also know you have to use coilovers or use other 510 parts to make it work. Just wondering I think I found a set in my garage. Eddie Quote Link to comment
sssr20det510 Posted April 5, 2013 Report Share Posted April 5, 2013 If I remember right they won't work. Go zx and u get bigger brakes too Quote Link to comment
Ranman72 Posted April 5, 2013 Report Share Posted April 5, 2013 angle of the strut is way off ZX is the way to go Quote Link to comment
datzenmike Posted April 5, 2013 Report Share Posted April 5, 2013 ZX struts move the tire out 3/4" per side, so if your tires barely tuck this may not work for you. ZX hub bearings are the better larger ones than the stock 510. ZX rotors are vented with larger calipers. 510 rotors are 231mm outer diameter and 147mm inner for a pad width of 84mm. ZX rotors are 251mm and 151mm pad width 3.94mm Quote Link to comment
edekalil Posted April 5, 2013 Author Report Share Posted April 5, 2013 Thanks I did not think they would work. I do have a set of 280zx struts also. Eddie Quote Link to comment
sssr20det510 Posted April 5, 2013 Report Share Posted April 5, 2013 zx moves it in not out, thats why you need zx to clear 15x8 0 offset on the front because if you have normal 510 struts they will stick too far out Quote Link to comment
edekalil Posted April 5, 2013 Author Report Share Posted April 5, 2013 Well what I have is a set of 280zx strut's with perches cut and 510 perches ready to be put on with split collers to hold then in place. I have bump or bum steer spacers I think that's what there called that go between the strut and lower ball joint the strut attaches to. I also have adjustable camber plates that attach at the top. The rims and tires are these in the pic. I have seen these used on 510's and just have to figure out what I will need to be aware of when doing it. I do not know what the 30 stands for or what the offset is on them. Eddie Quote Link to comment
