Eagle_Adam Posted November 27, 2013 Report Share Posted November 27, 2013 those bearings were NASTY!! Quote Link to comment
Cpl620 Posted November 28, 2013 Report Share Posted November 28, 2013 Sweeeet~ that ride should be pretty nice. Quote Link to comment
JNHEscher Posted November 28, 2013 Author Report Share Posted November 28, 2013 Thanks! Slowly but surely. Yes those were nasty bearings. Black and gritty. My center link and d shaft bearing came yesterday. I'm not sure how the shaft support will work out since its pulled out of the trans by an inch. When I was measuring for the rear links, my friend leaned against the tailgate and rolled the truck forward a bit. I didn't think anything of it, but turns out there was so much back lash in the gears that my measurement was an inch longer than it should have been. Not too big of a deal. Just makes the support mounting difficult. Quote Link to comment
datzenmike Posted November 28, 2013 Report Share Posted November 28, 2013 The black in the master is the rubber seals. They slowly rot and when you start using them again they just grind away. Quote Link to comment
JNHEscher Posted November 28, 2013 Author Report Share Posted November 28, 2013 There was indeed black funk. Haven't looked yet but is there a rebuild kit of sorts? I'll be working on it tonight and need to get some brakes in operation. May end up with a d21 master and calipers after all. Quote Link to comment
JNHEscher Posted November 28, 2013 Author Report Share Posted November 28, 2013 Several options on rock auto. Sure wish I had the time to list everything I need to order in one shot. Waiting another week, I guess. Quote Link to comment
JNHEscher Posted November 29, 2013 Author Report Share Posted November 29, 2013 D shaft bearing is in. The flap of rubber wrapped around the old bearing held the shaft better, but it doesn't look ghetto anymore. New center link in. I'll get the toe adjusted tomorrow at ride height. Master cylinder is off and the seals were shot. Ordering a Bendix rebuild in a few from RA, unless O'Reillys can get it tomorrow. Feeling accomplished tonight as I get closer to licensing my ride. Quote Link to comment
JNHEscher Posted December 1, 2013 Author Report Share Posted December 1, 2013 More accomplished. I'll just post the pics for you whores some time tomorrow. I'm going on my third week straight of 24 service call. Makes for a very difficult time when you want to work on your Datsun. Quote Link to comment
JNHEscher Posted December 2, 2013 Author Report Share Posted December 2, 2013 Sweet newness! New heater valve works great, and so does the heat. The fan's low speed resistor is no good, though. Went in O'Reilly's and picked out a random 3/4" heater hose with a 90 in it. Last owner used a straight piece that was kinked. 1 Quote Link to comment
JNHEscher Posted December 2, 2013 Author Report Share Posted December 2, 2013 Gauges work. I was finally able to let it idle long enough to make sure the heat and thermostat worked. Quote Link to comment
JNHEscher Posted December 2, 2013 Author Report Share Posted December 2, 2013 Shortened the fuel hose a bit so it had a better-flowing curve. Still need to adjust that center link you see down there. Got some bump steer, for sure. Quote Link to comment
JNHEscher Posted December 2, 2013 Author Report Share Posted December 2, 2013 14's with 720 brakes make for a close fit. Quote Link to comment
JNHEscher Posted December 2, 2013 Author Report Share Posted December 2, 2013 Looks like I'll be replacing a motor mount in the near future. Quote Link to comment
Eagle_Adam Posted December 3, 2013 Report Share Posted December 3, 2013 Last owner used a straight piece that was kinked. Not into kinky hoes? keep going man its lookn good Quote Link to comment
JNHEscher Posted December 4, 2013 Author Report Share Posted December 4, 2013 Not into kinky hoes? If they bend far enough ;) Quote Link to comment
JNHEscher Posted December 4, 2013 Author Report Share Posted December 4, 2013 Got the headlights working. Dirty contacts in the headlights switch wouldn't supply power to the relay, and then I found a loose wire on the relay for the low beams. Patrick came over and I had him run the clutch pedal so that I could adjust the slave cylinder. Perfect pedal feel now. Quote Link to comment
Eagle_Adam Posted December 4, 2013 Report Share Posted December 4, 2013 :thumbup: Quote Link to comment
JNHEscher Posted December 4, 2013 Author Report Share Posted December 4, 2013 Went into O'Reilly's this morning to check on the brake master status. The guy who I called didn't realize it was special order and required pre-payment. So, it didnt get ordered. Waiting another week. I didn't bother going through RA this time because I didn't want the hassle of returning parts if they were incorrect. I've had enough trouble with their stuff on this since it seems there's a different manufacturer making the parts for each side of the vehicle. Going to have to make my own tie rod for the right side. They sent the correct side this time, but it's not the same manufacturer. It has a larger diameter that rubs the air bag at full lock. On a lighter note, the clutch is so smooth that I'm pretty sure I can get my wife to learn to drive a stick in this one. L series have really good power for a 70's four-banger. Quote Link to comment
KlassicMotion Posted December 4, 2013 Report Share Posted December 4, 2013 I love the progress! Can't wait to see your reproduction parts too! Quote Link to comment
JNHEscher Posted December 5, 2013 Author Report Share Posted December 5, 2013 I love the progress! Can't wait to see your reproduction parts too! Two more days and I'm free to make parts happen. Last part to make the suspension stable. I chucked these bars in the lathe and turned it by hand while grinding them down to match the thread diameter. Threaded and extra 3 inches so that they would work on the 620 mounts. Quote Link to comment
JNHEscher Posted December 5, 2013 Author Report Share Posted December 5, 2013 Ended with this. 1 Quote Link to comment
Ron1200 Posted December 7, 2013 Report Share Posted December 7, 2013 Sweet newness! New heater valve works great, and so does the heat. The fan's low speed resistor is no good, though. Went in O'Reilly's and picked out a random 3/4" heater hose with a 90 in it. Last owner used a straight piece that was kinked. Under the dash, on the upper left side of the heater box is the fan resistor coil. You'll see two wires connected to it (Sorry I can't remember their color). The resistor coil is probably not connecting the terminals. Take it out. You'll find that it's either burned up or, like mine, the connection has come apart. Maybe you can reattach it? If you can't, you'll know which part you need to replace. Quote Link to comment
Ron1200 Posted December 7, 2013 Report Share Posted December 7, 2013 It's your lucky day... Found this in my Ratsun forum travels... Here is a post w/ pic of what I was describing... I reattached mine with a machine screw and nut. Like other heater fan problems, I had no low speed. The resistor is located next to the fan motor on the side of the heater box. No screws, it just snaps in. resistor unhooked, no low speed. resistor hooked back up, now both speeds on fan work. Quote Link to comment
JNHEscher Posted December 7, 2013 Author Report Share Posted December 7, 2013 It's your lucky day... Found this in my Ratsun forum travels... Here is a post w/ pic of what I was describing... I reattached mine with a machine screw and nut. Much appreciated. I was expecting to find a loose connection as that's what the majority of the electrical problems on my truck have been. I plan to get that fixed today. If the coil is burnt, I may look into a rheostat to wire into the full speed loop. Quote Link to comment
JNHEscher Posted December 7, 2013 Author Report Share Posted December 7, 2013 Resistor coil was just unhooked from the terminal. New reverse light switch just arrived. Quote Link to comment
