DISLEXICDIME Posted March 28, 2013 Report Share Posted March 28, 2013 so around 5 or 6 months ago i bought a late 260z It has a l28 5 speed r200 an edelbrock 500 cfm carb with a clifford intake and a mystery cam crane xr700 optical ignition set up lowering springs rewinds motor sports tc kit solid dif mount blah blah blah other stuff It also came with a full rubber seal kit it needs tires the rack has some play and the right rear shock is blown So far i have replaced the r200 with another r200 with 390's in it and i replaced the ignition switch and the rear transmission seal and trans mount . and tightened every bolt in the rear sub frame because they where all loose . and best of all it has ac hopefully i can get it working again . And now on with the pic's Quote Link to comment
Shawk910 Posted March 28, 2013 Report Share Posted March 28, 2013 Im lovin those pics ...sweet ride :thumbup: Quote Link to comment
DISLEXICDIME Posted March 28, 2013 Author Report Share Posted March 28, 2013 Thanks I was going to post more but photobucket freeked out Quote Link to comment
DISLEXICDIME Posted April 1, 2013 Author Report Share Posted April 1, 2013 with the help of phill I think we got the stating issue figured out . Thanks phil The optical sensor was loose in side the distributor and was moving around in side and throwing the timing out of wack . So i now i need to buy a new timing light so i can re time it and it should be good to go for now egine wise . Now i just need some 225 50 15's and rear shocks and she will be road worthy . I think i need to lower it at least another inch and some video ! it start's! Quote Link to comment
RedBanner Posted April 1, 2013 Report Share Posted April 1, 2013 Aahhh man, wont play for me, im shure it works for everyone else tho... of course Quote Link to comment
420n620 Posted April 1, 2013 Report Share Posted April 1, 2013 let me see if I can help you red. blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap blap Quote Link to comment
RedBanner Posted April 1, 2013 Report Share Posted April 1, 2013 Lolololol, I can Almost feel it lolol Quote Link to comment
izzo Posted April 1, 2013 Report Share Posted April 1, 2013 Aahhh man, wont play for me, im shure it works for everyone else tho... of course No, it wont work for me either. Damn photobucket video links. Don't work with new IPS... Quote Link to comment
DISLEXICDIME Posted April 2, 2013 Author Report Share Posted April 2, 2013 sorry dudes ! 420n620 does a good impersonation Quote Link to comment
Farmer Joe Posted April 2, 2013 Report Share Posted April 2, 2013 blapedy blap... sounds healthy. adam, its all you could imagine! :lol: 1 Quote Link to comment
420n620 Posted April 2, 2013 Report Share Posted April 2, 2013 Thanks Dislexicdime, it does sounds very healthy. A little surprised since you got one of them Eldumbrock carbs on their. like the deep throaty sound. :thumbup: Quote Link to comment
DISLEXICDIME Posted April 2, 2013 Author Report Share Posted April 2, 2013 I am surprised how well it runs with the edlbrock 500 on there. It pulls pretty good . Who ever tuned it new what they where doing Quote Link to comment
DISLEXICDIME Posted June 25, 2013 Author Report Share Posted June 25, 2013 well i thought me and phil had fixed the starting issue . I was wrong ! i ended up swapping out the crane cams optical trigger and wired in a na 280zx electronic distributor and it started right up shut it off turned it on and off 6 or 8 more times and bam! It would crank and crank crank then 2 -3 tries later and i got it started wtf . Any one now what this big metal twinky is? this is what it looks like inside Quote Link to comment
dat77sun Posted June 25, 2013 Report Share Posted June 25, 2013 looks like a big ass fuse Quote Link to comment
