Question for '68 510 owners (re: seatbelts)
AZhitman
Hey guys -
Can someone shed some light on the '68 4-door seatbelt mounting points for me?
My interior / upholstery is already installed (prior owner), so I don't want to go tearing it out / poking holes until I have a pretty good idea of the mounting point locations (especially if there's a mounting point in the b-pillar).
Oics would be even mo' betta.  :)
Thanks much!!!
-Greg
  • Replies 17
this is on my 68 2 door in 68 they didnt have shoulder harnesses but mine had some in it when I bought it
not sure if provisions were there factory or added by previous owner
push your finger around the b pillar and feel for a soft spot the size of a bolt and maybee someone else will post up 4 door pics
photobucket-67435-1364275583895_zpsd1190
photobucket-56453-1364275599843_zps5c3a9
photobucket-45077-1364275621462_zpsf75b1
Guest 510kamikazifreak
B piller lower was the same 2 and 4 dr
Upper was there in all(if I recall right)
They would not have retooled the whole line for such.
4 door inner dogleg is present on 2 drs inner..
Awesome.
"Same" = it's in the spot where Ranman's upper mount is?
If I remember correctly yes.
You should be able to "feal" around upper b pillar,and that will tell the tell.
Most anchor "nuts" are in the same spot
They don't look the same as what I've got.. at least the pics above. Thanks man!
I thought since everyone came in here saying they looked the same, that I wouldnt even bother. Ugh... making me do work and shit. Ill snap some in the morning for sure. Im free all day.
