67_1600 Posted September 30, 2013 Report Share Posted September 30, 2013 Also, make sure you're at the top of the compression stroke and not the exhaust stroke. This happens more times than you can imagine - the piston being at the highest point does not necessarily mean you're on the compression stroke. To be sure, take out the plug and put your thumb over the hole while the engine is rotated - the pressure of the compression stroke against your thumb will be unmistakable. 1 Quote Link to comment
robopineapple Posted October 1, 2013 Author Report Share Posted October 1, 2013 Been at work all day today, i will get pics tomorrow 1 Quote Link to comment
robopineapple Posted October 1, 2013 Author Report Share Posted October 1, 2013 hey adam... is this what you were talking about? i have it at TDC in this picture Quote Link to comment
Eagle_Adam Posted October 1, 2013 Report Share Posted October 1, 2013 you can not tell if the motor is at TDC from that pic. HOWEVER if it is at TDC on the compression stroke then you are a tooth off. Did you remove the oil pump? Quote Link to comment
Eagle_Adam Posted October 1, 2013 Report Share Posted October 1, 2013 http://community.ratsun.net/topic/41723-distributor-issue/ Quote Link to comment
Eagle_Adam Posted October 1, 2013 Report Share Posted October 1, 2013 also note the orientation of the "fat" and skinny" side on the shaft ;) Quote Link to comment
robopineapple Posted October 1, 2013 Author Report Share Posted October 1, 2013 I did take the pump appart, what do you mean by the note of the shaft? Quote Link to comment
Eagle_Adam Posted October 1, 2013 Report Share Posted October 1, 2013 look at the oil pump drive shaft that connects to the bottom of the dizzy the end of it has a fat end and a skinny end. The center is "off center" Quote Link to comment
robopineapple Posted October 5, 2013 Author Report Share Posted October 5, 2013 spudly came down and helped me out today, got my baby running again! thanks to all of you for the help :) means a lot to me Quote Link to comment
67_1600 Posted October 5, 2013 Report Share Posted October 5, 2013 Nice! And a perfect day to get it out on the road again. What did it end up being? Quote Link to comment
robopineapple Posted October 6, 2013 Author Report Share Posted October 6, 2013 The distributer timing Quote Link to comment
Eagle_Adam Posted October 7, 2013 Report Share Posted October 7, 2013 good to hear Quote Link to comment
robopineapple Posted October 7, 2013 Author Report Share Posted October 7, 2013 Welp... still running super hot. i need to replace my oil pan gasket too. how can i get my thermostat? i cant really think of why else it would still be over heating Quote Link to comment
Eagle_Adam Posted October 7, 2013 Report Share Posted October 7, 2013 hey adam... is this what you were talking about? i have it at TDC in this picture did you ever pull the oil pump and fix this? Quote Link to comment
67_1600 Posted October 7, 2013 Report Share Posted October 7, 2013 A lean mixture and retarded timing can both contribute to an engine running hot. What was your initial timing set at and was it done with the vacuum advance from the distributor disconnected? Also, I know you replaced the head gasket but did you get the head checked out before putting it all back together? Quote Link to comment
robopineapple Posted October 7, 2013 Author Report Share Posted October 7, 2013 Adam, i got the oil pump all squared away. i think the timing is just a little retarded. apparently the cam sprocket i have is really stupid, no marks on it haha thats why we had troubles. could still be a tooth off? Originaly we took everything appart wih the distributer and vacuumm on if thats what you are asking Quote Link to comment
Eagle_Adam Posted October 7, 2013 Report Share Posted October 7, 2013 with the motor at TDC what does the oil pump shaft look like with the dizzy off? then you need to see if your cam is timed right THEN you can look at dizzy timing itself Quote Link to comment
robopineapple Posted November 6, 2013 Author Report Share Posted November 6, 2013 so.... im not over heating anymore and the wagon is running awesome, but i am just oozing oil. i replaced the oil pan gasket and i redid all the gaskets that i messed with during the head gasket deal. i can figure out where all this oil is coming from because its all over everything. looks like its mostly coming from the passenger side, closer to the fire wall because there is a patch on the under side of my hood of oil and always a little pool of oil on my fuel filter thingy. the clear cylinder on the fuel line. i dont think its the head cause whatever it is its spraying everywhere and im not seeing any coming from the head. im leaking so much that i can fallow a dribble trail from the front of my complex to my appartment. like i said its all over everything so i cant pin point where its coming from. Any ideas? its even running down my exhaust pipe and dripping in the middle of the wagon because of it haha. the cross member is disgusting Quote Link to comment
bananahamuck Posted November 6, 2013 Report Share Posted November 6, 2013 Take it to the car wash and hose that bitch off,, don't spray anywhere near distributor or carburator NO WHERE NEAR .. Just start at the middle on the sides and work your way down ,, you should be able to see where the new oil at least comes from pretty close.. I use just the high pressure soap , forget the "engine cleaner" that's just a ripoff.. Buy yourself a can of WD40 and some paper towels in case you wash out the distributor somehow,,, BUY IT BEFORE YOU START,, better safe than stranded.. Again dont spray the dizzy or the carb cuz if you do,, you be fuckin up.. :cool: 1 Quote Link to comment
flatcat19 Posted November 6, 2013 Report Share Posted November 6, 2013 Better safe than stranded...Bwahahahaha. 1 Quote Link to comment
robopineapple Posted November 6, 2013 Author Report Share Posted November 6, 2013 I work in the same parking lot as a brown bear car wash so ill make sure to clean it up afyer work tomorrow. what would the wd40 be for? to make them more wet? lol. Quote Link to comment
bananahamuck Posted November 6, 2013 Report Share Posted November 6, 2013 Water Dispersant 40 Quote Link to comment
Fat510 Posted November 6, 2013 Report Share Posted November 6, 2013 That cressida that's sat your work is for sale :) Quote Link to comment
robopineapple Posted November 6, 2013 Author Report Share Posted November 6, 2013 Thanks nanner, i didnt know that was what the wd srood for! is it really for sale?? It hasnt been here in forever Quote Link to comment
